Geomety Question
Discussion in 'The Lounge' started by Resurrection_Joe, Mar 25, 2004.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Ok
    I need to find out how to map an equilateral triangle inside a circle that is centered in a square.
    The size of the square is all the real reference I have
    Id like to have the triangle point down inside the circle
    Uhghhh hard to ezplain
    Mainly because I dont really NEED the triangle, I just need 3 points on the circle 120 degrees apart with one being at 180*
    WAHGHGHH MY HEAD
  2. ncbloodhound
    ncbloodhound 1/2 ton status
    Aug 18, 2003
    400
    Indian Trail, NC
    got a picture?
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    See if this will do it (I think this is what you're talking about):
    Draw your square and make the circle touch all 4 sides...I think that's easy enough.
    Now, make crosshairs in your square/circle...this will be the center.
    Where the vertical crosshair hits the bottom line of the square, put a dot there. Then, take your protractor (angle measuring dohickey) and center it at the center point of your crosshairs. Now, put dots 120 degrees (from your dot on the bottom line) on the outside of the circle. Now you have 3 dots...connect 'em and you're done.
    Wow, I have no idea if I explained that in a coherent manner...let me know if you understand.
  4. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    i understood it
  5. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    What is the size of the square??? Do you have a compass (not the kind that shows which direction you are going)... If so, find the center by connecting the diagonals (like in the above description)Then set your compass so that it draws a circle that touches the box on each side. Without changing your compass setting, put it where the circle touches the bottom edge(this will be your bottom vertex), then mark the circle, move to that mark and make another mark on the circle....continue this until you get back to your starting point. You should make 6 marks(counting your starting point), just connect every other mark and you have an equilateral triangle. /forums/images/graemlins/thumb.gif
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Is this so you can get my doors finished /forums/images/graemlins/whistling.gif /forums/images/graemlins/rotfl.gif
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yes, yes it is.... and you're soft top is on the way with th other guy's driveshaft /forums/images/graemlins/tongue.gif
    Man I'm working here! I gotta plop down $150 dollars for steel to make doors I won't get payed for that I have to ship too! Ahhhh my head!
    Anyway back to circles
    I'm doing this all on my computer by the way so I can't be using so stinky protractoratormagig.
  8. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    What program are you using on the computer?
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Adobe Photoshop 7
