Gertag tranny?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DieselDan, Apr 5, 2002.
  1. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Did GM ever use a Gertag transmission in any of their trucks? How well were they built? What is the output spline and what transfer case did they come with?
    A friend says he has a five speed he'd sell me (cheap), but I only heard of the 89mm 5spd and the NV4500 (I know it's NOT a NV4500) in a GM. Did the 89mm have an intergral bell housing (he says this tranny does)? I want a manual but I NEED an OD. I would even consider running a doubler to make up for lack of a granny gear.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    The Getrag had the integral bell housing. 32 spline output and usually found with a NP241 behind them. These were found in the IFS trucks, and had the drivers side drop T-case.
    Honestly they are kind of a weak tranny, all aluminum case and no granny gear. Good for a light duty truck I guess, but i wouldn't think of swapping one in.
    Rene
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    It would probably be a lot cheaper to use an NV4500 for the OD and low gear rather than using a Getrag and a doubler. Better tranny to boot!
  4. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    I don't know about cheaper, as I have most of the parts to do a doubler now. Plus the cool factor of having something different. BUT the sturdiness of the Gertag is a big concern. I'm not comtemplating bolting this tranny behind a blown 502, just a turbo 6.2 (oil burner).
    Does anybody have any first hand experience with this tranny? Did it crap out on you? I worked at a Ferd dealer years ago and we did have problems with Gertags, but I don't remember that tranny looking quite like this one. Anyone have any info on the different models?
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I had one behind a 350 in an 88 GMC 1/2 ton 2WD pick-up (new body style). It's a nice shifting tranny, very much like a car 5 speed. It is a noisy tranny though, it always sounded like there was gravel floating around inside it...even when it was brand new. The only problem I had with mine was a small press pin sheared inside the shifter tower leaving me unable to shift. This happened at 40,000 miles and again 10,000 miles later. It's a top loader tranny and replacing that little pin is a PITA!!!
    By the time I sold the truck the synchro from first to second was showing signs of wear and it would grind a bit between gears now and then. It had 61,000 miles on it when I sold it.
    Rene
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Rene
  7. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Wow, 60K and the syncho is making noise? Pin breaking in the shifter, TWICE? Crap that just answered my questions. Thanks TRust. Guess the search for a NV is on!
