Get a load of this engine stand....dressed 454
Discussion in 'The Garage' started by PsRumors, Nov 29, 2006.
  1. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    I bought this stand as it is rated for 1250 lbs. Bought the 454 for the brackets and then to reseal it and sell it.
    Is this much sag normal? The engine can't be rotated as there is too much weight.
    I did re-center the engine in the brackets but didn't help any.
    I have another 454 which has been rebuilt and needs to be finished. I am scared to put it on the other stand I bought.
  2. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    dosen't look like the best quality, who manu. the stand?
  3. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    It's from Summit....like $80 or so
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you put it together backward... the piece that stands up goes on the other way...it should tilt back, not forwards...;):p:
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Did you put it together wrong? Looks like the upright piece that the engine head bolts into is pointing downward when it should be pointing upward. I'm not sure if that piece can be turned around 180* but if so that is your problem.
  6. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    unbolt the upright and turn it around.
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Man theres an echo in here:rolleyes::p:
  8. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Maybe its just me, but the whole upright piece is flexed. I think its a POS stand.
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    it isnt flexed its on backwards...
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Once you reverse the upright, then bolt the engine in place much lower on the stand. The way you have it now, the center of gravity is too high. If it did start to turn over, it would flip and probably dump the engine on the floor. :yikes: You want the center of the tubing for engine bracket to line up just above the crankshaft. Otherwise the engine is so top heavy that once it starts to move you can't stop it.
  11. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    put a block of wood under the balancer.
  12. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    Nope it's not put together wrong.....prior to the engine going on it is tilted back. It is a POS stand.
    It is bolted together properly the upright is flexed that much. These will be going back to Summit.
  13. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    The problem isn't the vertical part (red bar in photo).....it's the bracket connected to the engine (the black part)
    Look at the photo again..... That bracket has an "offset" to it. Two fingers are very close to the centerline of the part that allows the engine to rotate. the other two are SUBSTANTIALLY longer.
    You have the BLACK bracket mounted upside down. The LONG fingers are supposed to be supporting the engine block down low, and the two fingers with almost no offset are supposed to hold the upper mounts of the block.
    That engine is sitting about 12" inches TOO HIGH on the stand, which is why it's creating all the leverage that is bending the crap out of the vertical bar. Change that black bracket around so that the engine sits lower on the stand, and I'll bet you $$$ that the whole thing looks a lot better.
    :deal:
  14. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    I noticed that after I took the picture. But I did correct that and it still bent like crazy.
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    As the saying goes.......
    "You get what you pay for"
  16. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    So who makes a good stand and where do you get it?
  17. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    .....and sometimes you really pay for what you get. :haha:
    My engine stand cost more than $80, but it has a nice handle on it....and you can crank it and the engine rotates around oh...so smoothly.
    I spent the extra money for a really nice cherry picker too.... I hate struggling with crappy tools, especially ones that hold big things (jacks, engine stands, etc). My pet peeve is that even with the "nicer" tools, they still seem to all cheap-out on the casters....they never seem to swivel or roll correctly when there's weight on them. Bah! :mad:
  18. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    Yup...... :bow:
    Keep buying that Harbor Freight stuff boys.... :rolleyes:
    I can imagine the quality you get in a $9 grinder... :doah: :haha:
  19. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Both of my stands are $40 cheapies from HF and both have held fully dressed BB Olds before with no problems. Looks like you got bent (no pun intended).
  20. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
