Get My Balancer Off
Discussion in 'The Garage' started by mtnman210, Jan 28, 2006.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    Ok Does anybody have any ideas on how I can get it off. It's on the front of a 454. I've got the block completly torn down but I can get the balancer off. I've broke 2 pullers already......Don't you just love P.O. surprises:rolleyes:
  2. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    lol I KNOW WHT U ARE GOING THRU
    im about ready to hook the back of the block up to a tree, and hook the balancer up to a truck and give it hell. lol
    Let me know what works for you
    brad
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I was thinking the same thing---long strap to the hitch and a full throttle yank:haha:
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    They come off easily with a harmonic balancer puller.
  5. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    there fixed it for ya:D
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I've heard that if you yank your crank.....(braile).
    If the bal. is seized or "Oh my God!" welded, you'll straighten the crank if you pull it.
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    any chance of getting it on a hydraulic press and pushing the snout of the crank out of the balancer instead of trying to pull the balancer off
  8. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    machine shop
  9. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    a good brand name puller not a parts store special
  10. ryoken
    Jun 13, 2003
    29,624
    1,379
    Jersey Shore
  11. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    :haha: :haha: :haha: I like that.
    are you using one with jaws, or one which actually bolts onto the balancer? i assume you're using the one which bolts on. if so - i have no idea how to help you. if not - you should use one. if you have - you may as well try the one with jaws. when i pulled mine, it was a cheap crappy one from napa or something, and i broke it, but they replaced it for free and since the first one had moved it a relatively far distance, the second one didn't have to go very far to get it off. anyway, fwiw
  12. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    If you use the puller with jaws you will destroy the harmonic balancer by pulling the inertia ring off the inner hub then he would have to buy a new balancer.
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i assumed that he was replacing it.
  14. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    these were the pullers I was using
    and this is the pain in the a** in question.
    I have to toss the crank but was hoping to save the balancer. But now I think I might just trash the balancer too so the new one will be easier to put on. It might be seeing the hot end of a torch here very soon:mad:
  15. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's quite the puller set up! i think if i were you, i'd just get a new balancer - they don't cost that much. then again, i'm paranoid about them b/c i have the 6.2. ;) got mine for $75, and i think gassers are cheaper still.
  16. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I have news for you, if you think that balancer is hard to get off wait until you try to install a NEW balancer, they are very hard to get installed all the way on.
  17. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Harmonic Balancer
    Dude, are you serious, I was just getting ready to tackle that job.I got my new roller chain on,2 pc. alum. timing cover on, and was getting ready to buy my harmonic balancer. Mine came off so easy I just thought it would
    be the same in reverse, then again I just have a small block!!!!
  18. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I know what you mean... the couple I've pulled in the past slid right off. This thing is just being stubborn
  19. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    That looks like RUST between the crank and the balancer, could be siezed!! How about a good penetrant, since you want to save the balancer
  20. ryoken
    Jun 13, 2003
    29,624
    1,379
    Jersey Shore
    do NOT do that... use an installer....
