Get this $%^#. I love trannys
Discussion in 'The Garage' started by adamforsythe, Jan 3, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Well my truck went into the shop about 3 weeks ago to get the front seal changed on the tranny. Well while the truck was there reverse went on the good old Th350. So instead of installing a HEAVY CAM. I am going to build a NEW Th350. I am adding a shift kit STAGE 2 (street/strip). With a heaver TC. Then next summer I am going to gut the floor pan and rebuild it.
    Adam
  2. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    sounds like a plan but also sounds like the shop you had the truck at was beating the truck up and blew reverse, unless you knew the guy than MAYBE its different
    otherwise good for you and i bet it was time for some fresh stuff anyway
    LUKE
  3. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    so reverse worked when you brought it to the shop. but then reverse magically broke while it was at the shop? is that correct?
    if that's true i'd be asking the shop how and why they broke my transmission.:mad:
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Actually, that kind of stuff happens all the time.
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Well reverse was slipping a little bit ever since I had it. But I think running the thing out of fluid killed it. What is a Th350 rated for HP wize?
    Adam
  6. blackblazer717
    Jul 1, 2004
    470
    massachusetts
    i would say i f it was fresh about 400HP
    LUKE
    p.s. but thats just what ive sceen in a car with regular tires and 4:10's but could be different with a big tire and axles
