getten hot hot hot
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ramjet gmc, Aug 11, 2003.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I went on the UPC trail run this weekend and I had some trouble with over heating I want to find out more a bought a big block radiator and electric fans ( other then the ford toures ) any thoughts--------- and the set up is a 350 with a 89 front end
    Any pics of your setup
    /forums/images/graemlins/confused.gif
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I use the dual winstar fans on my car. They cover the complete radiator and work well. Im going to install them on my Blazer. Fans
    The Mark-VIII single fan is also a good choice, pulls about 5000CFM but is pretty loud.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    hey i like that one /forums/images/graemlins/thumb.gif
  4. ramjet gmc
    Dec 19, 2001
    3,370
    Can I say it?
    - That looks hot /forums/images/graemlins/grin.gif
    Is that from 1windstar or 2
    And did you use a thermostat or toggle switch
    That must be a custom fan shroud
    I like it /forums/images/graemlins/thumb.gif
  5. 88Silverado
    Mar 13, 2003
    2,664
    That is a standard 1995 Ford Winstar fan setup.
    It is dual fans in the molded shroud.
    Took some slight trimming to make it fit but was pretty easy. Heres another link to the guy who turned me on to the setup Winstar Fans
    I have a thermal sensor in the block that kicks in at 205 and off at 185 (I run a 180 stat) I also have it wired to the A/C compressor so when the air is on, the fans turn on.
    I ran each fan thru a 50A relay but have them both come on at one time. Some have one fan running full time and the second one come on when needed.
    I have another set of fans in the garage, will probably install them this winter. The factory clutch fan is noisy as hell and feels like a big load on the engine.
    Also, I have heard of some folks using the smaller Taurus fan and mount it inside the factory shroud (against the radiator) and leave the stock fan insitu. They have a switch to turn on the electric fan when wheeling.
    The fans pull 30+ amps, make sure your alternator is up to the additional load.
    Theres another one or two pics of the fans on my car at This link.
  6. ramjet gmc
    Dec 19, 2001
    3,370
    i like this i may go this way no one park your windstar near me /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just so you guys know, typically a mechanical fan has been known to pull more air than an electric. Your overheating is likely because of a plugged up radiator rather than a crappy fan.
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah but if your are wheeling and not pulling many RPMs how much air do you really think is moving? Vs. an electric that is just pulling full on air.
  9. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Looks sweet! What kind of additional load is the alternator seeing with the fans? How much did you spend on the fan upgrade, not including a new alternator if you put one in? Thanks!
    Kris
  10. dyeager535
    26,980
    Just depends how the fan was designed. It's a compromise of sorts, since the engine/ mechanical fan RPM is variable.
  11. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    That is a sick setup, that is a seemingly plentiful setup from a junk yard.
