Gettin Funky with gas
Discussion in 'The Garage' started by Chevy305, May 29, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    So I noticed that everytime I fill up my tank with the usual 93 octane, my truck sudden gains pep. Like it opens up. Then about a day later it loses some of its get up and go that it gained with the gas. Why does this happen?
    My fuel filter is no more than 2 months old, gas tank/sender unit about 2 years old. It doesn't matter what station I go to, but usually I go to the local Hess station.
  2. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
  3. bigjak
    bigjak Newbie
    Mar 24, 2003
    Maybe your fuel tank vent is plugged up. When you put in the fuel, your releasing the vacuum, then after a while of driving, the vacuum builds back up.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I have no answer other than to ask, why are you running 93 in a 305? Are you one of those "I make more power and get better mileage on 93" people?
  5. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    What year is the engine and is it carb or ? What it could be is that the gas is clogging the injectors or nozzles after it has been sitting. If your engine does not require higher octane gas then it doesn't need it. If your truck only runs on regular unleaded then thats all you need.
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    http://truckworld.tenmagazines.com/mygallery.ten?id=9814
    here is his truck info, its a collection of things, unless he knows exactly how his fuel system is set up we are grasping at straws
  7. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    My 305 is a L69 from a Firebird so it has a compression of around 9.5 and I have always been under the impression that it needs a higher octane. The timing is adjusted properly. I never did try to run anything lower and I don't think I get more power or any mileage gains purely from running on 93 octane. (mileage is kinda a mute point with my truck)
    My truck has the stock fuel system and a single feed 4bbl Holley carb (model is 4160)
    Where is the vent located, and how do I unclog it?
  8. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
  9. resurrected_jimmy
    May 23, 2005
    2,241
    If this is the case you should be able to unscrew the gas cap for a couple of days to test this theory.
  10. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I did that today and I got the extra get up and go I was talking about.
    Is the vent tube the smaller hose that is next to the filler neck on the gas tank?
  11. dyeager535
    26,977
    Vent tube runs to the front of the truck, to the EVAP cannister. Prior to EVAP, most if not all just used a vented gas cap, which seem to be impossible to find.
    The one you are talking about is just to vent the tank when you fill it up.
  12. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Yeah, all emissions equiptment were removed by the previous owner. So I don't think I have an evap cannister. My gas tank has 3 lines that all run directly to the fuel pump, then 1 line continues to the carb. Could replacing my gas cap fix the problem? or maybe the fuel pump?
    Sorry I am a little clueless about this issue.
  13. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
  14. dyeager535
    26,977
    Well what happened to the vent line?
    If plugged off to remove the emissions stuff, then you either have to run a vented gas cap, OR vent the line some other way.
    All gas caps are actually vented, but the only ones I've seen for sale at parts stores are the later high pressure ones, which don't work with unvented tanks.
