Gettin PS Belt tight?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Dec 5, 2001.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Okay, I've tried everything...but the belt is still not tight enough (squeels like a pig when I splah shrough water). I've tried having my girlfriend pull on a crow bar wrapped around the pulley nose while I pul w/ one hand and tighten with the other...still not good enough...how the hell do you guys get yours tight enough?
    <font color=red>1987 Blazer K5, 4" Rancho Lift, 33" BFG AT, Dual Battery setup, AND MORE TO COME [​IMG]
    Was that a speed bump? No, just a Rice Rocket </font color=red>
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    How old is the belt and what condition is the belt in?
    Don't hit me, Mr. Moderator... I'll go back on topic... I swear![​IMG]
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Maybe loosen the AC compressor belt first to relieve the pressure on the other belts. Then tighten up the PS belt. It worked for me.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    it's prob not the belt being loose, it could be that the belt is old and glazed over or that the pully has lost it's grip. try a new belt or try roughing up the pully with a little sand paper and see what happens. you don't make it to tight or it could harm the pump
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like the belt is a goner. It shouldn't need to be that tight. Make it too tight and you'll quickly ruin the bearings in the pump. The belt surface is probably glazed from getting too hot. [​IMG]
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    When you get your new belt on, you'll notice a square nut that's been welded to the front of the brace/mount. I think its a 3/4" wrench that fits on there so you don't puncture the resevoir with a pry bar or whatever. If you need I'll take a picture for you and post it later. And like everyone said you don't want it sooooper tight.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  7. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    You [​IMG]REALLY[​IMG] shouldn't need the PS belt that tight!
    When was the last time that the belt was replaced?
    You might also check the pulley for glazing, you can sometimes remove the glazing with isopropyl alcohol.
    Forget the belt squeak sprays that are sold, except for temporary fixes, either replace the belt or the pulley and be squeak-free for a few years.
    The fact that it squeaks when wet, makes me think that the glazing may have built up on the pulley to a point where it cannot be saved.
    <font color=blue>I don't know everything, I just think that I do.............</font color=blue>[​IMG]
