Gettin the stroker kit got questions??
Discussion in 'The Garage' started by CaveBlazin, Feb 23, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    383 Stroker Kit
    Silvolite Hypereutic Pistons
    Hastings Moly Rings
    Clevite High Performance Rod Bearings
    Clevite High Performance Main Bearings
    Melling High Volume Oil Pump
    PBM Gasket Kit
    PBM Camshaft RV Towing Cam RPM range of 1500-5500 and its a class II
    PBM Lifters
    Durabond Cam Bearings
    Pioneer Brass Expansion Plugs
    PBM Dual Row Timing
    PBM Hydraulic Valve Springs
    PBM Chrome Moly Retainers
    PBM 7deg HD Keepers
    Scat Crankshaft 3.750 Stroke 2 Piece Seal 5.7 Rod
    SBC standard pushrods
    Ok here's my questions:
    1.)I have stock 882 heads and wanna add new valves, any tips on what kind and upgrades to them?
    2.)Is that a decent cam and range?
    3.)Should I upgrade the valve seals cause there the rubber ring types?
    4.)Any other suggestions on upgrades for this kit? I wanna do this right the first time Im sure yall understand...
    Thanks,
    Semper Fi,
    Spence :woot:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you are running a carb an rv cam seems fine. If you have tbi/tpi get a comp cams dual pattern cam, there is alisting at their website. As for the heads I am not sure, I just bolt them on and go. Now you don know about the grinding needed done to make crank clear block, and possibly the bolts on pushrod to clear cam. /forums/images/graemlins/k5.gif
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Yeah the block is at the shop now being fixed as we speak Im getting a good deal on the machine work from a very reputable source, so that will save me some greenbacks. Any more tips are welcomed /forums/images/graemlins/peace.gif
