getting 4.56s soon... got some???s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, May 29, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    okay ya'll say how bad it is to run in 4-hi on the road, then how the heck do you break in the front gears? if it's so bad for the truck to run with the hubs locked in what do i do? i've done 1 rear end swap before so i know what i'm doing /forums/images/icons/crazy.gif(kinda) so how long will it take me and a buddie or two to do both axles? i'm afraid the suburban will be down for a week and i'll have to drive daddy's f*rd. /forums/images/icons/crazy.gif
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I will have my front gears (4.56) installed soon, and want to know the same thing about breaking them in. Maybe run in 4hi with the hubs unlocked, so it will still rotate the gears with pressure on them, but not be driving the wheels, as apposed to running the hubs locked and the case in 2hi?
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There will not be any pressure on the gears if you drive in 4hi with the hubs unlocked. You will not damage anything by running in 4hi on the street or highway. Think about it for a minute, trucks with original NP203 case is a fulltime 4x4. It doesn't know if you are in dirt or highway. And before anyone brings up the fact about there being a differential in a NP203 case I know that. There still will not be any damage from running in 4hi on the highway. Besides, it's not like you are going to do it just because and for any length of time either, just to break in the new gears then back to 2hi
  4. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    What about my truck with the 208? And doesn't Muddysub's have a 241?
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    It doesn't matter what trans case you have, it will not hurt it unless for some crazy reason you have different gear ratios in your diffs. I have a NP241 in my truck as well.
  6. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    But when you turn, doesn't the frontend have to travel further/faster than the rear end, so that would create bind in the transfer case? My truck would always "hop" in a tight turn on high traction surfaces shortly followed by one of the front wheels slipping. It would be pretty lame trying to explain to my friends how I broke a front axle u-joint while on the street! And... the recommended break in period is 500 miles, that is a lot of miles to be in 4wd on the street!
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The 203 has an internal differential built into it that allows give between the front and the rear axles. This allows you to drive on the pavement with it. The other transfer cases (205,208, etc) that do not have some type of slip-allowing will bind up on the street. Especially when cornering. Looks like you will be forced to take extended off-road trips. Bummer.
  8. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Personally. I would not drive on the street for 500 miiles in 4wd. Just me though.
    I will just break them in wheeling on my own vehicle.
    Ken H.
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    You can drive in 4WD with the hubs unlocked, but you can risk some damage to your hub gears (though not likely). You can also run with the hubs locked but in 2WD. Neither of these will put much pressure or load on the gears, but it is better than nothing.
    I ran mine like that for quite some time after installing my 4.56s. Then I just took it easy for a while when off-roading. They have worked like a charm for me.
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You should provide your mailing address, so that the folks that follow your advice can send you a bill for their repairs. /forums/images/icons/shocked.gif
  11. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I would not worry about breaking in the front gears as much as the rear. If you have any dirt or gravel roads near you just run a few trips down them in 4 wheel.
  12. muddysub
    Jun 23, 2001
    10,452
    489
    thanks guys! /forums/images/icons/smile.gif i think i'll just run with the hubs locked in 2-hi unless someone else tells me otherwise. oh and the extended off road trip... that's gonna be rough, really. /forums/images/icons/frown.gif/forums/images/icons/wink.gif
  13. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Take your rear driveshaft off and run in 4W hi. Then your powering the front only. You can't do this if you have a rear slip joint on the TC.
  14. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Hehe. /forums/images/icons/smile.gif
    Send the bill.
    Ken H.
  15. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Find a long stretch of dirt road, put it in 4 hi, and drive about 10 minutes or 15 miles, then take a long lunch break and let the gears and oil cool down. You have to have the front hubs locked otherwise the wear pattern it establishes wont be for the axle under a load. Keep in mind if you have to drive somewhere where before you can drive it in 4 hi, that counts as time and mileage and you have to let it cool before you go break in the front gears. Keep it under 60 mph as well.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's what I'd do. Hubs locked, 2 hi. Run it 50 miles and let it cool, run it a little more, and call it broke in.
