Getting a stuck rear window down??
Discussion in 'The Garage' started by 4xcrazy, Mar 18, 2004.
  1. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Buddy of mine has a '91 Blazer, the rear window will not roll down, this also is keeping the tailgate from dropping down. Any ideas on how to get this winder down? to fix the problem. Does it consist of taking the rear panel and cover off and digging around inside there?
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    If its power the motor might be out. You need to take the rear gate panel off and un-screw the cable from the motor. Them take a drill and put the cable in it and go at a slow speed. It will open and close for him that way. Just dont do it to fast and to often.
    Hope this helps. /forums/images/graemlins/thumb.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Whether its a manual or electric, you still have to pull the access panel.
    For electric, pull the panel and undo the cable from the motor, and connect a drill motor to the cable end and use the drill motor to roll the window down. On a manual window, its just a matter of getting to the crank mechanism from within the inside.
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    before I'd take anything apart I would check the plug connections at the firewall and the tailgate. Use a test light and have your friend hit the switch. Mine has come upluged once or twice at the firewall while wheeling.
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Yeah, it's electric, thanks for the ideas, will check it out tomorrow. /forums/images/graemlins/thumb.gif
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    A brick. /forums/images/graemlins/thumb.gif
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Thats what i told him, well kinda, he asked me if i knew of a way to get it down, and i said sure, (with a serious look on my face) i opened the back of the Burb, and pulled out the 5 lb. sledge hammer. /forums/images/graemlins/yikes.gif Yeah, he thought that was reeeeeal funny. /forums/images/graemlins/whistling.gif
