getting angles right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85GMCJimmy, Jun 25, 2001.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    How do you determine your driveshaft angles, in order to determing the degree of a shim to use. Where do you measure to get your 2 angles?
  2. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    Angle finder, off the pinion, should give the same # as off the T-case if you're not running a CV, or same (within a degree or two) of the driveshaft itself if you have a CV at one end. If you happen to get a driveshaft built with CV's at each end, don't worry 'bout it. :-)
    --Rob
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you happen to get a driveshaft with a CV at the front and a u joint at the other end, forget about it. I've never seen one with CVs at both ends. But anyway, if you do get a CV shaft, rotate the pinion up until it's directly in line with the shaft for the best u-joint life. If you do that without the CV it'll vibrate like crazy.
    Tim
  4. Ryeguy
    Oct 30, 2000
    Victoria, B.C.
    Big luxury cars ran driveshafts with CV's at each end.
    --Rob
  5. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Measure the angle off the pinion on the axle:
    http://www.zing.com/picture/pc3bb1e10ac07473fff801baa69474c56/fe7cd267.jpg.orig.jpg
    Make sure the angles match perfectly. Or no more than like 2 degrees difference.
    <A target="_blank" HREF=http://www.zing.com/picture/pe748cc976c85e294dee4122e92d02569/fe82e282.jpg.orig.jpg>http://www.zing.com/picture/pe748cc976c85e294dee4122e92d02569/fe82e282.jpg.orig.jpg</A>
    I'm running the stock shaft and 5" of lift (lowered Tcase 1") and no vibes, until I hit about 75 to 80, but they're still not that bad. With that said though, I will be getting a rear 1350 CV shaft (HighAngle Driveshafts) after a few other mods [​IMG]
    And yes, double sided CV shafts do exist! [​IMG] Talk about pricey and over kill [​IMG] But would be nice [​IMG]
    Boss
    89' 1 TON of FUN K5
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yeah Boss has the down low for ya. If you haven't dropped the tcase it will aid a lot in easing your vibrations.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
