Getting end cap off PS gear box
Discussion in 'The Garage' started by 8_YOUR_H2, Dec 29, 2005.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I am debating on doing my own drill and tap for hydro or buying the EMS caps. My question is how does the end cap come off the PS gear box after you get the huge snap ring out? I was thinking if I could crank the wheel the pressure would pop it out but the gear box is out of the truck. Maybe weld a piece of steel to the end of the cap to pull on???:confused:
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    It's aluminum....Your first idea will work. Use a chanel lock, wrap the shaft with a rag and turn the shaft and the end cap will be pushed out.
    ****Beware, the balls will follow shortly, so be prepaired!!!!!
  3. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I ran a self tapping screw into the middle of the cap and used a claw hammer to pry it out quick and easy, plus you don't blow oil or the balls out of the box!
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thanks, I just found a new sig:D
  5. Stomper
    May 11, 2002
    3,767
    Iowa
  6. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I like this one too
  7. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    :haha: :haha: :haha: thats a good one hehehehe
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Couple of beers and reading that, I can't stop laughing!!!!
  9. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Once you lose your balls it's a bitch. :haha:
  10. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I lost mine.:o Out the top while porting the box. Wasn't paying attention and plop, everything fell out and went everywhere.:eek1: :mad:
    Anyone got a box rebuilding write-up? Might as well do it all right now. :bow:
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've pushed the caps off two boxes while they were on the bench just by turning the input shaft and letting the piston push them out. If you turn the input just enough to get the cap pushed out you shouldn't lose your balls :eek1:
