Getting flexy with a fork lift!
Discussion in 'The Garage' started by white-rhyno, Apr 13, 2003.
  1. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    My front tire is only 27" off the ground? What would that be in RTI??
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I can't tell if your truck is a K5 with a truck cab or a shortbed truck. If it's a shortbed truck then your RTI is 672 on a 20 degree ramp, if it's a K5 then it's 741. </font>
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Is the passenger rear hitting the flatbed? It looks like you could stuff a little more in the front, if you put tubs on the flatbed you could probably flex a bit more, that is if you are hitting the bed.
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Looks like a K5
    and it says BLAZER on the front fenders
  5. white-rhyno
    Jan 27, 2002
    942
    Hey thanks bunches shaggy. Yes it is a k5. My old body was useless so I threw a cab on it. I have about another 1/2 till my tire hits the flat bed.
  6. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    Nice k-5
    Hey if you in Ellensburg next time i go to seatle ill have to yell at you, i usually stop there for gas.
  7. white-rhyno
    Jan 27, 2002
    942
    Thanks, I work right in Ellensburg. PM if your going through.
  8. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    i used a fork lift on my SB truck and got 38" what is that on an RTI?
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> 946 on a 20 degree, 647 on a 30. </font>
  10. white-rhyno
    Jan 27, 2002
    942
    Yo shaggy... Can you give me the equation to figure that out with both 20 and 30 degree ramps please.
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
  12. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Is your sway bar still hooked up?
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Your front axle is barely twisting. Is the sway bar still hooked up or do you have really stiff front springs?
  14. white-rhyno
    Jan 27, 2002
    942
    Sway bar is long gone. Those are BDS 6" springs. I was always under the impression they were soft. Dosent seem like it. My shackles are also 1.5" longer. Dont really know if that is benneficial or not.
