Getting grease out of upholstery?
Discussion in 'The Garage' started by laketex, Mar 24, 2003.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Yeah I was stupid and put some rims in the backseat floorboard of my ram. They had some grease on them and now it's on the back of my tan front seat. It's that fuzzy upholstery. I haven't touched it with anything yet for fear of grinding it in deeper. Somebody mentioned oxyclean....any other good suggestions for how to get this chit out? I'm thinking of selling this truck and it's gonna be a little difficult to do with greasy seats! /forums/images/graemlins/eek.gif
    Bryan
  2. LoggieStyle
    LoggieStyle Registered Member
    Jul 10, 2002
    78
    Tujunga, CA
    gum-out or goo-gone, stuff like that would probably work too but oxyclean works well on grease and would be the least likely to leave any stains.
    Logan
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Oxyclean works pretty good but if all else fails try WD-40.
    I've used it to get grease stains out of car seats and the carpet in the house (wool and cotton) and it works great. Once you get the grease stains out then give it a good shampoo to clean up any residual WD-40 (it's a little stinky).
    But, like anything else, test it on a small out of the way spot to make sure it won't totally screw up your fabric.
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I detail for a living and I use zep industrial cleaner thier purple stuff, about $8.00 for a gallon but works on every thing, also didi wonders in my carpet inside the house where stuff is tracked in. Just dilute it about 1/2 way. /forums/images/graemlins/thumb.gif
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    NO! I bought some of that oxyclean stuff and didn't care for it. I sprayed it on let it set and tried scrubbing it out... no go, just rubbed it in farther (it did ok on the carpet, but not on the seats). I saw a new 'Resolve' ad on tv for a foaming cleaner for household carpets. That would probley be better. Foam sits longer then water. I would try spraying the foamy stuff on and rub it around litely and let it sit. Then use a spray bottle to rinse it off (hold a towel under it). That way you rinsing the cleaner out and not rubbing it around. /forums/images/graemlins/smirk.gif Might work, the foamy carpet cleaner I use to get from AutoZero they dont have anymore.
    I did mix up a spray bottle of the oxy cleaner and it done wonders on the dirt on my door panels and door jams. If you let it sit too long on the dash vinyl it discolors, leaves white spots on stuff and it does not work that great on glass. I was trying to use as an all around cleaner getting the DIRT out of the project truck. I had to use two 24 oz bottles (about one tablespoon of oxyclean per bottle) /forums/images/graemlins/thumb.gif
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I use Go-Jo and it seams to work pretty good and doesn't tear things up or fade out the color...
  7. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Try some WD-40 then use freebreeze to get the smell out
  8. Grim-Reaper
    7,385
    Atlanta
    M-1 Remover/ cleaner. Stinks like hell but it will get tar out. dip a old tooth brush in it and then blot it with a paper towel.
  9. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    TUFF STUFF, you can find it at wal-mart. i've found that it works great on grease and things like that just use a soft scrub brush with it.
  10. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    May want to try a little brake cleaner. I used it on carpeting in my truck and at home. It works wonders, but the usual disclaimers apply, check small area first... yadda yadda...
    John
  11. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Simple Green...Usually works on anything and I have used it on auto carpet with good results.
  12. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I put another vote in for zep. It works a lot better than just about anything I've tried including oxyclean and simple green.
    This may be a stupid question, but if you have a truck, why not put the "greasy" wheels in the bed? /forums/images/graemlins/grin.gif
    BIGJ
  13. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    ok we have two votes for zep but where do you buy the stuff?
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    when I was working on the oil drilling rig in the tar-sands I used GOJO hand cleaner to clean the tar and oil out of the upholstery of the rented suburban.
    it worked surprizingly well, I bought some for home
  15. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I've had good luck using GOJO also, followed by simple green to get the GOJO smell out if water doesn't get it all.
  16. laketex
    6,220
    North Texas
    Allright, looks like zep, gojo, or simple green. Where do I get the zep?
    And btw BigJ....I happened to have 4-42's and 4-36's in the bed. being a swb with a toolbox, the bed was already rather full! Am I gonna see you in ourkansas in a couple weeks?
  17. BIGJ
    896
    Central Arkansas
    I figured there was a good reason for not putting them in the bed /forums/images/graemlins/smile.gif Yep, I'll be at Hot Springs all weekend.
    I picked up some zep from a friend that has a detail business. He said you can buy it at home depot, although they may not have all of their products. Here is their website.
    BIGJ
  18. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Oxy clean wont work on thick grease very well. Try quick and bright. I've used it before on car greasy stuff, and it worked for me.
  19. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Theres also Folex. Its a insanely strong upolstry cleaner. Ive used it, and its worked on things worse than grease.
  20. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    stinky? what? i love that smell. . .as i do gasoline- the best smell in the world. . . why do all the good smelling things have to be carcinogenic?!!?
