Getting harder to shift into 4Lo
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by SHINTON, Jul 2, 2002.
  1. SHINTON
    SHINTON 1/2 ton status
    Dec 26, 2001
    148
    Kernersville, NC
    The Jimmy seems to be getting much harder to shift into 4Lo, I will try this week again to remember the steps. I remember I was getting almost a gears against gears sound?
    I always put the tranmission in Neutral, then shift the tcase. Is there a specific procedure I should be following? How about when you shift back into 2Hi? Seems like I remember old Dodges or something you were supposed to 'back up' a few feet to disengage the 4wd?
    I dont remember it being nearly as hard or making the noise a few years ago? Could it be something as silly as low fluid?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If the gears are grinding when you are stopped the tranny might still be spinning some. Try it in park and see what happens.
