Getting hydro assist
Discussion in 'The Garage' started by Loose Nut, Oct 27, 2006.
  1. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    Need a list of everything ill need please :) Wanna order it all at once.
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I'd check with some of the vendors here. I'm sure they would be glad to assist....:D
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  4. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    After fubaring a rebuilt box I would have to suggest just getting the EMS cap and tapping the top of the box. Hoses and ram and your done.
  5. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    81JimmySLT offers a RockLogic kit with the EMS caps for a little over $300. :thumb:
  6. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    AGR Performance
    AGR Performance has a kit for your rig. I owned one for my Powerstroke and it worked great! Steered like a Caddy; gearbox on driver side, ram on passenger side working together.
  7. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I run the westtexasoffroad 2wd steering box that is ported for hydro assist, and a PSC ram. I would personally go with the PSC because of the bigger fittings for more flow, the heims are much larger and has a male end on the body side, and female on the ram side(much stronger). PSC also sells hose kits for a good price.
    Instead of porting the 2wd box, i would get the www.jkwoffroad.com steering box end that is already ported for hydro, all you got to do is tap the top lid yourself or send it to JKW with 10 bucks and he will tap it for you. using the pre-tapped ends on the box is easier if you break a fitting or the box goes out...
    Also, install a tranny cooler as your powersteering cooler to add to fluid capacity. No need to extend the filler neck like many have done. Just put the cooler on your low pressure side, and you will have plenty of fluid to run the ram.
  8. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Those rams were gone a long time ago.
  10. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Doesn't ORD sell PSC kits and WTO kits? might wanna give em a call.....
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i got mine from him and i love it!:bow:
  12. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Thanks Loose Nut............ You will love the difference.
    Jesse
  13. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    np jessie :) was a pleasure ordering from ya. Im hoping this will solve all of my little problems im having.
    ill be sure to let ya know what i think and ill take pics of the set up when its done.
