Getting nice, deep sound from your truck
Discussion in 'The Garage' started by PetaKane, Jul 5, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I've got Dynomax headers, dual Magnaflow mufflers, and my truck just sounds so weak. I like the nice, deep rumble that you hear coming from hotrods. How much does your motor have to do with the way your truck sounds? I am going to get my crate motor installed later this year. Do low compression motors sound different than high comp? Does the camshaft have anything to do with sound? It's not that it's just sound I'm going for, I like performance first and foremost. But most high performance vehicles sound really good, meanwhile mine sounds like a stock Toyota Tacoma.
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Flowmaster makes a cure for that but your catalytic converter might be stifling the sound a bit too. Lower compression and higher compression engines do sound different, the camshaft can change the sound a bit too.
  3. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Well, no cats. I was gonna go Flowmasters, but alot of people on here recommended Magnaflows. I just went with what I could get the cheapest. Maybe I screwed up. People are always telling me how mean my truck looks, then I start it up and alot of people kinda smirk. Ya know what a truck sounds like with straight headers when it's idling? That's what I want mine to sound like.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You want a low rumble??! I have cutouts, so basically I just have cats(8" long) and pipes that dump just before the axle. No mufflers. The cats make the sound more deep as compared to just open headers. BTW I have a stock 350.
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    if you want a rumbel.. get a 4 inch pipe on the end of your exhaust.. only needs to be about 15 inches long.. NICE low rumble...
  6. Mike.S
    Mike.S Registered Member
    Jul 4, 2002
    30
    S.E.TN.
    I think the cam does have something to do with it. I have a RV cam in my 462ci and it lobe's very well. I also run Dynomax headers to 3 chamber Flowmasters and then to turn downs right before the rear axle. My truck shakes the ground but has that deep rumble too, which the cam is responsible for. Seems to me what you need is a good cam, NO cadilac, and Flowmasters.
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Flowmaster..and a high flow cat. Also add some 3" tips. There you go!
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I've got a Magnaflow hi-flow cat and Flowmaster 1 chamber. It's loud.
