Getting ready to put the fuel tank back in... vapor canister line
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jjlaughner, Apr 30, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Do I need this? I thought about removing the can to make way for some mods. If not I need to find a rubber line to run with the fuel lines. Theres a rubber line on the canister but it disappears under the motor somewhere and there are no rubber lines past the tranny /forums/images/graemlins/thinking.gif
    Am I correct in assuming the vapor line goes to the canister? /forums/images/graemlins/confused.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine's been plugged for two years now I think.
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yeah I think that is whats going to happen here. I was just wondering if its worth leaving hooked up?
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Yes it is worth hooking up. It sends the extra fuel vapors thru a charcol filter rather than straight to the atmosphere. It is an effective pollution control with little to no maintenence required and also doesnt hurt the performance of your truck /forums/images/graemlins/thumb.gif
  5. dyeager535
    26,976
    Not only that, but if you don't vent the tank with another cap (which apparently can/will eat your paint around the fill neck after years) it will build up excessive pressure inside which can cause more problems.
    Also, the EVAP system should be fairly effective at keeping condensation from getting into your tank (an early low pressure vented gas cap may work too) which will rust it inside out.
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/thinking.gif maybe I will relocate it to another place then. Its going to be in the way. Now I have to go by 20ft of rubber line /forums/images/graemlins/rolleyes.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    If your really bent on getting rid of the charcol canistor, put a check valve on the end of that line, so it continues to vent...simliar to an axle vent line check valve....my buddies '77 1 ton had one from the factory
