Getting ready to test drive the blazer.. trans fluid drainage question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Jul 22, 2003.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Okay.. put in the 205/400 combo..
    Dropped the 700/241..
    The old burnt up fluid is still in some of the lines..
    what's the best way to get it out?
    Do I disconnect one of the lines on the radiator and crank it over til the clean fluid comes out?
    And if that's the way to do it.. which line do I disconnect?
    Or... does anyone have any better ideas?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check with the local auto parts house for a can of aerosol tranny cooler flush. It connects to one of the lines, then forces a cleaning solvent through the line, the cooler, and then the other line (into a bucket, not your tranny! /forums/images/graemlins/wink.gif ) I suspect that you then need to flush the lines with compresed air, then hook everything back up and fill up the tranny with ATF. /forums/images/graemlins/thumb.gif
  3. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Harry...
    Appreciate the quick response..
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Rocko,
    You are probably finished by the time you see this, but just did this a couple of weeks ago, two cans of the trans-cooler flush and lots of compressed air.
  5. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks guys..
    I'm going to attempt it this weekend..
    Keep yer fingers crossed... /forums/images/graemlins/smile.gif
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    If the tranny is installed, A simple way to flush it is to disconnect the top radiator line (return side) connect a hose to the radiator connecton and drop it into a big bucket. Secure the hose in the bucket so it doesnt fly around (makes a real mess...trust me on this one) Start it up and let it run for about 5-10 seconds then shut it off and add fluid. This will work fine for cleaning out the old stuff in the lines and cooler (this will pump 2-3 quarts out, It will start to spit air when the fluid gets below the pump level).It takes about 12 quarts to get a complete flush (torque convert). I do a complete flush yearly to my vehicles and have had great luck with longevity.
    Since your tranny is out, you can clean the lines out with compressed air. A small amount of burnt fluid left in the lines or cooler will be greatly diluted and will not affect the new fluid.
  7. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    88.. thanks for the detailed instructions.. and tips..
    I greatly appreciate it..
    Can't wait to take it for her test run.. should be this weekend..
