Getting rid of TBI saddle tanks.. what is the best way
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by camiswelding, Nov 27, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Is using a suburban tbi tank and putting it behind the axle the way to go?
    what about a custom tank...?
    (must be smog legal)
    thanks
    cam
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    easiest way would be a sub or a blazer tank, and they will be smog legal if all the hoses are hooked back up
    the large blazer tank is 31 gallons
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I'll buy one of those tbi sending unit/fuel pump, assemblies from ya, (if your sellin) let me know via PM thanx M
  4. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    This is the fuel tank I am going to replace my saddle tanks with. This is a 45 gallon aluminized diamond plate steel fuel tank. It bolts into the bed of the truck...right behind the cab. A high pressure OEM TBI in-tank fuel pump can be used, and it is 50 state smog legal.
    Here is a link to the company that makes them. http://www.aerotanks.com/
  5. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I put a blazer tank in my longbed to get rid of saddle bag tanks. It was not a bolt in affair. I made cross members cause the stock ones won't work without mods. I doubt a blazer tank would fit in a shorbed without being above the axle, which would be bad unless you got 17" of lift or you never flex it.
    If you wanna know more or need pics, PM me.
  6. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks orion....
    Im going to trial fit a k5 tank... or see if I should fab up one...
    Ill let you know about the pics if I need some additional ideas...
    My truck is a longbed dually 60" cab to axle...
    cam
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Know where to get these cheap?
    This is the fuel tank I am going to replace my saddle tanks with. This is a 45 gallon aluminized diamond plate fuel tank. It bolts into the bed of the truck...right behind the cab. A high pressure OEM TBI in-tank fuel pump can be used, and it is 50 state smog legal.
  8. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    Longbed, you got lots o' room behind the axle, no?
    Burb tanks in 87-91 came in 43 gallon, I do believe.
    I also *think* there was a pickup tank for under the bed somewhere, but all I've ever seen is the saddle tanks.
    -- A
  9. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    What had TBI saddle tanks? (what year rather).
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I know my '87 stepside does, and I would imagine all R/V body style 87-91 trucks do.
  11. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    A 40 gallon sub tank fits nicely but you need to pay attention to when everything lines up. But it will fit. All I did was make two simple crossmembers and cut out the tire carrier and the rear crossmember. My hitch works good to replace the rear crossmember.
  12. bonanza
    bonanza Registered Member
    Oct 18, 2004
    55
    Sterling, IL
    Anyone got any pictures of this swap?
  13. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Quote:
    These type of fuel tanks are pretty expensive...about $500 (not including the brackets and hardware needed to mount OE fuel pump and fuel filler neck)
  14. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    [/ QUOTE ] No but I can take some for you. /forums/images/graemlins/waytogo.gif
  15. bonanza
    Oct 18, 2004
    55
    Sterling, IL
    Thanks, I've got the 25 gallon tank already and I thought it was gonna be a no brainer, but I'm starting to think it's gonna be more than I first thought.
