getting rid of the sticky things in the tub?
Discussion in 'The Lounge' started by LKJR, Aug 14, 2005.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    you know those stick on grip things people put in the bottom of the bathtub? well the previous tennant here tried to pull them up but that glue they use should be sold to NASA (problem solved)
    I've been soaking them in goo gone and using a brillo pad and putty knife to pull them up but even that dosen't work well.
    anyone have any suggestions?
  2. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Die grinder?
  3. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    BFH. Removes anything.
  4. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    you could try a big wire cup on a 4 1/2" grinder...
    lacquer thinner will cut glue better than anything..
  5. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    Fiberglass tub??
    You could try a hair dryer or heat gun,if the tub isn't fiberglass...if it is,your limited as to what solvents you can use to loosen the glue...I'd suggest carb cleaner,but that has tolune and acetone in it,both eat fiberglass! :doah: ..how about a single edge razor blade in a holder?....or if its really stuck,cant you just LEAVE it in there?? :rolleyes: :crazy:
  6. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    sheesh, i thought he was talkin about a Blazer tub... duh... :o
    in that case a wirewheel wouldn't be too good eh? ;)
    lacquer thinner is still best for the glue tho..
  7. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Do it carefully, otherwise your going to have to yank the tub, well, if you care what it looks like, because most tubs have a porcelin finish over the top, try not to damadge the porcelin :crazy:
  8. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    isoprophenol alcohol. We it let it set for a little maybe with rag soaked in it on top of the spot then scrape at it. just like you would laquer thinner. This what alot of people to get the glue for window tint off. Maybe a little scotch brite pad will help too.
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Just make sure there's no water in the tub.:wink1:
  10. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    laquer thinner is your best bet alcohal just doesent cut it.
    if you go to an automotive paint suply and get your thiner there that stuff is the most powerfull, the stuff inhardwear store seems to be cut with something cheap like paint thiner or turpintine.
    i get mine at shurman colour your world, and automotive only store::waytogo:"
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    WD-40 removes most of those types of adhesives.
    If not a 'glass tub can also try Acetone or MEK. Both of those are pretty aromatic, so turn the fan on high.
  12. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    Yeah my landlord told me it was my problem to get the glue off. Acetone worked good but when the tub gets dirty they showed up a little.
  13. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    thanks guys I'll give some of those a try
