Getting sick of it. Nothing fits.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Aug 26, 2002.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Ok, I ordered poly-urethane bushings for my leafs. The package I got said proudly, 4WD 88-95 K5 Blazer, Suburban. But later trying them they turned out to be about 1/3 inch to wide. How can this be? Do I have some weird leafs or anything.
    Well, with that failed, I thought I'd roll the rear axle under and deal with the bushings later. But when I landed the drive shaft on the (what is it called?) U-Yoke, it not either. I always thought and have been told the 12bolt rear is a complete bolt up when replacing a 10bolt rear. Bit the 10 bolt rear seems to accept a larger drive shaft. What do I have to do now? One option is a cusom made drive shaft, but could I order a u-yoke that does fit?
    Please help.
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i just went threw the same thing this weekend...aparently the springs were changed k5's...so you need to get the bushings for up to model year 87...i can get you the part number for em...if i remember right the number stamped on the bushings should be 2004....and the ones that dident fit were 2041 or something along thos lines...ill find out tommorow for ya (thos are numbers from energy suspension)
  3. Sammy
    Dec 8, 2000
    250
    Cool. I have the same brand. Numbers were 2102 and 2101 I think.
    I do hope the shop will take mine back though. Paid big time money for it. $180 for all springs and shackles.
  4. Chaz88K5
    2,979
    Stockton/Lodi CA
    ok that sounds like the first ones i had...so you do have the wrong ones...the part# stamped on the bushing itself should be 2004...ill look for the part number of the kit tommorow...i threw the package away at the shop so i get to go dumpster diving to look for it...hehe /forums/images/icons/grin.gif
  5. Chaz88K5
    2,979
    Stockton/Lodi CA
    ok the part number for the kit you need is 53.2004R that is a energy suspension number...at one of the local shops around here it ran me 42.00
  6. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    The simple fix is buy a conversion u-joint that has the 10 bolt caps on one side and the 12 bolt caps on the other. some conversion u-joints are kinda pricey but still a lot cheaper than having a new end put on the shaft.
  7. Sammy
    Dec 8, 2000
    250
    So that is the rear leaf kit, with the shackle bushings as well? Or even a full kit for the whole rig?
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    or get a yoke for the dif
  9. Chaz88K5
    2,979
    Stockton/Lodi CA
    that is the rear kit only...springs and schackles
  10. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Maybe your girlfriend in Australia knows...... /forums/images/icons/tongue.gif
  11. Sammy
    Dec 8, 2000
    250
    Thanks Chaz, you're a big help.
    As for the driveshaft problem, I've searched every shop and junkyard, but no luck. (at least not a price I can live with) Now the plan is to weld a Chevy drive shaft and a (don't laugh too loud please) Jeep drive shaft together.
    As for that last thing that was brought up, we broke up and she drives Toyota anyway. But this site is for our cars, not our private lives. Or am I wrong?
  12. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    ROTFLMAO!!!!!!!!!!
  13. Robbie6987
    Robbie6987 1/2 ton status
    Jul 16, 2002
    111
    killeen TX
    You can swap the 10 bolt yoke to the 12 bolt but your going have to buy a 16.00 seal at napa PN CR 19277
    This info thanks to <font color="red"> </font color> K5DRAGER
    Also a seal for a 87 k-5 10 bolt front should work from Autozone
    P/N 8662 its only 6.00
    But i dont know for sure yet about the autozone seal ill find out tommorow.
  14. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    I converted my Blazer to a 12 bolt rear also, I just used the yoke from the 10 bolt and had to replace the pinion seal with the same one mentioned above. Easy enough...
  15. Can Can
    15,552
    136
    Funny how all of a sudden she's out of your life......How's your gunshot wound healing? /forums/images/icons/tongue.gif /forums/images/icons/crazy.gif
  16. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Rather well I would have to say.... get a new tranny yet btw? /forums/images/icons/grin.gif /forums/images/icons/smirk.gif
  17. Can Can
    15,552
    136
    Hehe!!! Fawking trolls, eh? /forums/images/icons/wink.gif
  18. Sammy
    Dec 8, 2000
    250
    Thanks for reminding me that event. I'm still not walking normal from that. Now please get out of my personal life and get a life your own.
  19. Can Can
    15,552
    136
    Boohoo
  20. Sammy
    Dec 8, 2000
    250
    Very American. Bye
