Getting stubborn stereing arm off...Any tricks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Jul 25, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am started to install my 6" lift today and began be trying to get the steering arm off the axle...The damn thing won't move...I took the 3 nuts off the top and began to pund the living daylights out of it with a hammer and an air chisel...no luck...any ideas on getting the thing off...
    Chris
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Just how big of a hammer were you using? I used a 10 pound sledge. Hit down on it the first time to try and loosen the cones then go to town. It should come loose. But be careful of the studs. I hit mine and deformed them beyond repair.
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I was using a measly 1.5lb framing hammer...I guess I will wack it tomorro with AT LEAST A 5 lb sledge
    Chris
  4. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Use a BFH. 5lb sledge.
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Hit down and side to side, not up and get yerself a 'man's hammer'. /forums/images/icons/grin.gif When the cone washers come a litle loose use some needle nose pliers or whatever to pry em out. Once the washers are out the arm should come right off.
    Heat helps, so does penetrating oil (spray it now, beat on it tomorrow)
    Rene
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Back the nuts off, but leave them on the studs so that the nut is protecting them. /forums/images/icons/cool.gif New nuts are WAY cheaper than new studs (and alot easier to install! /forums/images/icons/shocked.gif ) I leave the nuts with about 1/4 of the threaded part above the stud and 3/4 of it threaded onto the stud. Then smack straight down between and around the studs. When you smack it just right, the cone washers will pop right up! /forums/images/icons/cool.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you use a torch, be careful, you'll kill your upper balljoint!
  8. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    A FRIEND TAUGHT ME HOW TO DO THIS. TAKE THE NUTS OFF THEN WITH A HAMMER HIT THE ARM UP. THEN TAKE A LARGE SOCKET AND COVER THE STUDS AND USE HAMMER AND HIT THE SOCKET TO STRIKE DOWN ON THE ARM. TAKE SOME CHANNEL LOCK PLIERS AND GRAB THE CONE WASHERS. TURN THEM AS IF THEY WERE A THREADED NUT AND THEN ONCE THERE ALITTLE WAYS OUT PULL THEM THE REST OF THE WAY OFF. ONCE THEY ARE GONE THE ARM WILL COME UP WITH EASE. /forums/images/icons/grin.gif
  9. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    A 5 lbs. hammer and a can of man muscle.
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    a BIG FLIPPIN HAMMER and a can of whoop a$$
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Spray them with something.. I like break free and let them soak for a few hours..Then use your BFH...
  12. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Spray- PB Blaster then take a BFH to it. Don't hit it upwards, only side to side and down. Good luck
  13. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Yep. I was torching mine and hitting it with a 3lb. hammer and that didn't work. I eventually went to the store and got a real BFH (10lbs.). It came of with a few wacks to the side and down!!
    Good luck! /forums/images/icons/smile.gif
  14. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I ended up getting it off with a 5lb sledge...but the drag link end is still in it and jack it up pretty good trying to get it out...so I said screw it and bout a new drag link end...Thaks for the help guys...
    Chris
