Getting the imput shaft off of the steering box?
Discussion in 'The Garage' started by weisel, Sep 25, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I can't figure out how to get the damn thing off so I can replace the seal on the box. I took the bolts off the damper, unbolted the holding bolt (for lack of better term) for the splined part attached to the box, and for the spline part attached on the upper end (that goes to the steerng wheel). What is the trick to this thing? Isn't the shaft suppose to slide into itself to get shorter, so I can pull one side off the splines? It woun't slide though. The only other thing I can think of is to pull the box off the frame and slide the box down and forward off the shaft. Someone please help because I don't want to go through that much work. There must be an easier way.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    hummm...do you have acess to a digi-cam so we can see the problem?
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Could be like my toyota. It had a plastic pin holding the shaft together. I melted the plastic pin out in order to stretch the shaft out for a body lift.
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    you have to remove the box from the frame to get the input shaft off , rather remove 3 bolt closer to the shaft and pivot the box on the last bolt and then you can pry off the splined part
  5. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    I finaly did remove the 3 bolts from the box to get it
    slid back and the shaft came right out. Put the
    new seal in and no leaks! Yippie! And I pressed
    out the dang plastic things holding the shaft
    together. So now it slides up and down inside
    itself so if I ever need to take it off again, I woun't
    need to take the box off the frame. I then put a
    cotter pin through the holes in the shaft to hold it
    together (replace the plastic ones) so I can take it
    out whenever I want.
    Thanks for the help guys.
