getting the input shaft off the sterring box?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Sep 25, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I can't figure out how to get the damn thing off so I can replace the seal on the box. I took the bolts off the damper, unbolted the holding bolt (for lack of better term) for the splined part attached to the box, and for the spline part attached on the upper end (that goes to the steerng wheel). What is the trick to this thing? Isn't the shaft suppose to slide into itself to get shorter, so I can pull one side off the splines? It woun't slide though. The only other thing I can think of is to pull the box off the frame and slide the box down and forward off the shaft. Someone please help because I don't want to go through that much work. There must be an easier way.
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    After you unbolt the steering shaft from the ragjoint, push it (or tie it) to the side. Then loosen the through bolt. You will probably have to use a screwdriver or chisel to spread the collar apart enough to get it off of the splined end poking out of the box. It also may be rusted on so I would suggest a penetrant. I would also suggest replacing the ragjoint while you have it apart.
  3. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    I'll go give it a try right now..be back with feedback.
  4. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    No good. It woun't slide away from the box far enough to get off of the splined shaft. What gives?
  5. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    I finaly did remove the 3 bolts from the box to get it
    slid back and the shaft came right out. Put the
    new seal in and no leaks! Yippie! And I pressed
    out the dang plastic things holding the shaft
    together. So now it slides up and down inside
    itself so if I ever need to take it off again, I woun't
    need to take the box off the frame. I then put a
    cotter pin through the holes in the shaft to hold it
    together (replace the plastic ones) so I can take it
    out whenever I want.
