getting zero-rates soon... will my shocks be ok?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Feb 13, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    it's only one inch, will it make a difference? i have the stock dual shock mounts with RS-5000s all around. oh and how hard will these be to install?
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I didn't have any problems with the shocks, and my zero rate, but my rear springs do sag a little. As for install, its easy. This is what I did. I supported the rear of the truck on jackstands, took off the rear tires, unbolted the axle, lowered it, removed the center pin, and installed the new center pin and zero rate. Then reversed the process.
    The only part that was tricky was getting the axle low enough to get the new center pin in. I had to cut them before I put them into the springs. I left them about an inch to long. To get the axle low enough, I put a third jack stand on one side of the axle and lowered the jack to the point where the drum opposite the 3rd jackstand was almost on the ground. Then I had room to get the new center pin and zero rate in. Then I repeated the process for the other side. Cut the center pins after they are in to fit under the spring plate, and bolt the axle in.
    My Chevy isn't broken, its just out of gas.
  3. muddysub
    Jun 23, 2001
    10,452
    489
    thanks a lot!
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd put a c clamp over the springs before you go removing the center pins. It'll be much easier then.
    Tim
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, I forgot to put that part in. I did use a c-clip to hold the spring pack together.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It would be really straight forward if you had the tall jackstand, but I only had the normal heighth ones. I also only have 2.5" of lift, if you have more then that you WILL need the tall jackstand. I barely could get the zero rate in with only 2.5" of lift and normal height stands.
  7. ben794X4
    ben794X4 Registered Member
    Aug 29, 2001
    53
    Boise Idaho
    here is a dumb question. what are/is a zero-rate
    79 4x4 k5 stock
    3spd granny stock 350
    12 bolt open rear
    10 bolt open front
    Subvert the accepted paradigm.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is a 1 inch lift block that is bolted into your spring pack to provide an extra inch of lift for the sagging rear ends of a GM or anyother reason you have to lift the truck an inch. It is available from Offroad Design of $30, and they just came out with a new one you can read about in the Offroad Design forum.
