gimme sum driveshaft advice please!
Discussion in 'The Garage' started by rwright07, Sep 3, 2005.
  1. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    bad slip yolk in front driveshaft... broken splines
    took it out
    i found a used one for 125 bucks at a slavage yard...
    a hookup of mine told me he could get a new one for 225 balenced and everything
    whatdo u think...
    keep in mind im a 16yr old student low on money
    if u got a spare ud sell for cheaper id be glad to hear bout that too
    thanks,
    rick
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    how is the female end of the slip yoke?
  3. GruntHunter
    GruntHunter 1/2 ton status
    Apr 28, 2002
    145
    Florida (Space Coast)
    I just went through the same scenerio. I stripped out the spline. LMC sells them for $250. If you buy a used one I still wouldn't install it without replacing all 3 of the 'U'-Joints. I found that where I've been getting my oil change and lube jobs they miss the 'U' joints and I'm sure the fitting on the drive shaft. I neat trick I saw was putting a shock boot over the spline slip joint and securing it with SS hose clamps to keep it somewhat clean.
    $125 sounds high for one out of a salvage yard that you'll still need to rebuild.
  4. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Where about in WA are you? I have a front and a rear driveline off a '76 K5 I'll sell ya for $40....Need rebuild.:deal:
  5. rwright07
    Jul 30, 2005
    536
    corporate hobo
    i duno i havent pulled it apart to check the female end yet...
    i dropped it off at my buddys shop n hes gunna look at it w/ me in a couple days
    so it sounds like i should get the new one for 225?
  6. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    i have found used feals tight with old dry grease and dirt. but when all clean and new grease its sloppy. best bang for the buck and time is new .
  7. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
  8. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
  9. rwright07
    Jul 30, 2005
    536
    corporate hobo
    i have a 76 blazer,
    will a later model driveshaft fit?
  10. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    I have access to the driveline shop at work, it's in Everett.
  11. xanthias
    xanthias 1/2 ton status
    Nov 18, 2004
    195
    Houston, Texas
    [hijack]
    I have a somewhat related questions--I have some old '76 shafts I'm going to try to refurbish myself.
    1. My slip yoke on the front shaft is very stiff. Is it okay to pull completely apart forcibly to inspect/clean?
    2. Anyone have a p/n for the "ball" section of the CV? I think I can figure out all the u-joint p/n's.
    [/hijack]
  12. xanthias
    Nov 18, 2004
    195
    Houston, Texas
    ^^bump for question^^
    :bow:
