Ginding 4hweel low to High
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89fullsiz, Mar 28, 2004.
  1. 89fullsiz
    89fullsiz Registered Member
    Mar 23, 2004
    96
    Portland, OR
    Just took my Blazer wheeling for the first time. I have to say its a pretty capible vehicle!! I followed a crazy jeep and 4 runner that were going up everything. My stock Blazer followed them just fine on 32's in the mud up the hills everywhere that I could fit (although it got close in some areas) My Truck is COVERED in mud /forums/images/graemlins/cool.gif
    Anyways question is everything works good but when I go from 4wheel low into high it grinds a bit. I don't know if this is normal, if I'm doing something wrong or what I'm TOTALLY new to all of this! I have a 89 Blazer I'm assuming is stock with a 350tbi 241 case and 700r4 tranny.
    Is the grinding normal? Not normal but not a big deal? Am I a dumbass and I need to do something special before putting it into 4wheel high???
    I'll take pics and post them soon in the garage. Next time were taken the digital video I'll post those on the website /forums/images/graemlins/smile.gif
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    This is because of the automatic transmission. In nuetral, there is enough drag in the clutches that the output shaft will spin if there is no load on it. The only sure fire way to avoid the grinding with an auto is to shut off the engine and leave the transmission in nuetral. I'm not sure how "bad" the ginding is but mine has done it dozens of times. I just had it open and all of the gears and sprockets look find.
  3. 89fullsiz
    Mar 23, 2004
    96
    Portland, OR
    Cool the grinding isn't really bad and doesn't really stop you from putting it in 4wh high just didn't know if it is something going out or anything... If its normal I'm not going to worry about it /forums/images/graemlins/smile.gif
    Thanks!!!
    Bobby
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    actually, putting it in park will mechanically stop the output shaft from turning, so you can leave it running
  5. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    [quote
    Of course, but it also can cause binding in the driveline so that it is difficult or impossible to shift the transfer case. Plus, if you already have the Transfer Case in Nuetral and the output shaft of the tranny is turning, shifting to Park will just cause parking pawl ratcheting.
  6. 89fullsiz
    Mar 23, 2004
    96
    Portland, OR
    If I try to do it in park it won't even go into 4wheel high that is why I thought it needed to be in neutral? Man I need to get an owners manual or something /forums/images/graemlins/dunno.gif
  7. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    they way you shift into 4lo from 4hi is out the shifter on the steering column in neutral, then shift smoothly from 4lo to 4-hi, and vice versa, going from 2hi to 4 high you can shift at any speed below 25 mph, but 4hi to 4 lo, like i said, stop the truck, put it in neutral, and on one swift smooth motion put it in 4lo /forums/images/graemlins/thumb.gif
  8. 89fullsiz
    Mar 23, 2004
    96
    Portland, OR
    Yeah it grinds going back into 4wheel high when I do exactly that. I stop the truck make sure wheels are straight put it in Neutral then put the transfer case in Neutral then when I put it into 4wheel high it grinds a little....
    Nice to know on the 4wheel high I was doing the same thing for that stopping\neutral /forums/images/graemlins/smile.gif
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    dont pause in neutral on the t-case do it in one smooth motion, or it will grind, i get my info from the service manual in the glove box that came with the truck /forums/images/graemlins/thumb.gif
  10. 89fullsiz
    Mar 23, 2004
    96
    Portland, OR
    Cool I'll try that what is that nuetral for then???
  11. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Running the PTO.
  12. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Mine only does that when she slips and hits the shifter,,eerrr, /forums/images/graemlins/whistling.gif i mean uh, aww nevermind /forums/images/graemlins/doah.gif
  13. 89fullsiz
    Mar 23, 2004
    96
    Portland, OR
    You mean like a wench or something right?? PTO ???
