ginding noise .....kind of
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Nov 19, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    when i'm driving down the road and let off of the gas i get like a slight grinding kind of noise.and ony know what it might be?
    hola
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Where is it coming from? rear... middle or front of the truck? Most likely I would say bearings in the rear end (mopst likely pinion, but maybe carrier). This can also sometime because by worn u-jt's or a worn CV jt, tcase, or even sticking brakes.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  3. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    -Mikey
  4. If you have the factory posi (Gov Loc,I'm told), then the next sound you will probably be hearing is a loud "thunk!" and the sound of screeching rubber as the rear end locks up. I just had the pin from my posi come loose a couple of weeks ago. Before the locker went out, the rear end had a gear whine coming from it. The guy I bought the truck from said that posi's always make that noise, and I was ignorant enough to believe him. Thank God I was only doin' thirty when that rear end cut loose, or.....Well let's just say I don't want to think about the consequences.
    American by birth, Marine by the grace of God
  5. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Try putting in a bottle of GM posi lube.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  6. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    You need to tell us where the noise is coming from. I had a grinding noise coming from my blazer when i let off the gas. It turned out to be a worm sleeve in the T-case. Cost about $250 to get it rebuilt. It had 170K miles on it.
