Give me the ups and downs of a 6" lift for a daily driver
Discussion in 'The Garage' started by MEGALADON, Oct 1, 2005.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    I really really want to go with a 6" lift and 15/10 with 35/12 1/2 tires.
    I have an 82 GMC P/K with 10 bolts front and rear. Not sure if its a weak point. The truck will not be offroaded, maybe some beach time. I like the
    look of the lift with those size tires, I want to know if I can get a nice or
    soft ride with a all spring lift, and whats a good shock to go with for comfort.
    I have a 454 with a 700R-4 trans. Not sure what a 82 came with for a tranfer case, but it works well.
    I'm sure this has came up a millon times here, but lets hear everyones input,
    and post some pic's with 6" and 35 tires.
    THANKS ALL :bow:
    I would also like to know if this is dangerous for street driving, does it affect my breaking, will it be a whole lot easier to turn the truck over If I have to steer hard to the left or right to aviod an accident. I just love the pose of the truck with a setup like that, but want to be able to have fun on the streets to.
  2. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    6" and 35's aren't gonna mess with you that bad. Yes... braking will be impacted... and yes... so will acceleration. I doubt with the stock brakes you'd be able to lock up.... but you can stop well enough. DD... I say it's fine. I had one... it was great.
  3. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    So I take it I don't have to worry about poping my axels, or breaking anything.
  4. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    how much wheeling do you plan on doing? I assume they're 10 bolts with 3.73's...?
  5. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    No wheelin or off road use, mabe some beach time only. not sure on the gear ratio, but yes, 10 bolts front and rear. I am building the truck just for looks, but need it to perform as a driver also. I don't know if a 6" lift and 35's are for mainly offroad use only or can perform on the sreets also.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    You can get it to perform on the street but if your gears are anything (numerically) less that 3.73's I wouldn't even consider it.
  7. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I tried the 33/12 1/2 with a 10" rim and it looks good, but I want to get higher.
  8. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    How can I find out?? :doah:
  9. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    lift the truck up... spin the driveshaft twice... count how many revolutions the tired does.
    if it look slike 3 and 3/4... it's 3.73 etc...
    and yes... that'd be absolutely fine. If it's street and relatively light offroad then you'll be good. Maybe even with gears anywhere in the 3's?
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    The most foolproof way is to pull the diff. cover and count teeth on the ring and pinion. Your t-case is a 203 by the way.
  11. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    definately the most foolproof... but you know me... gotta do it the lazy way!
  12. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    Is that a good t-case, All I know is that its aluminium
  13. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    I did it with my crew cab -
    6" Rough Country kit
    35" BFG's
    16.5x12 welds
    4.56's
    I don't see any problems with doing it, I'm very happy with my truck and it's been daily driven (6 days a week) for 3 years now. It doesn't have any ill manners on the road, it's just plain fun to drive. The only thing I would do different would be to use rear lift springs instead of blocks (lots of wrap up).
    I did have to have the OE exhaust crossover rerouted to clear front driveshaft (which was plenty long enough for the lift).
    Depending on your current gear ratio, I would at least go with a 3.73. That said, my 4.56's feel perfect.
  14. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Your truck should have come with a 208 t-case.
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Your t-case should be iron, and it should be very long with three sections to it. If not, I'm a moron and they introduced auto locking hubs well before I realized it. Just a question, how'd you get a 454, and a 203 case in an '82 half ton?
  16. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Auto locking and full time hubs are completely different. The 203 (available thru 79) used full time hubs, or more simply put, internal style drive flanges. The auto locking hubs were used on part time 4wd trucks (beginning in 81, I believe) and they offered the convenience of not having to get out and turn a knob. Unfortunately the auto locking hubs were unreliable and destined to fail.
  17. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Sorry, looked and immediately thought 203 drive flanges, must be autolockers. My fault.
  18. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    thats what I thought, I know its completly stock when I bought it, except
    someone put a 350 trans in place of the 700r-4, But i am putting the 700r-4 back in. the t-case is aluminium, and I don't have to go lock my hubs, or get out of the truck to use 4 wheel drive, to get out of 4x4, I just back up 10 feet in reverse ;)
  19. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    The ups is you'll be up in the air, need I say any more. :p:
  20. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I wouldn't put a 700R4 behind a BBC with possibly wanting to run 35's and not knowing the gears in the axles. You wouldn't be able to use the OD if you have 3.08 gears, and the possibilities of burning it up are just to great.
    When I pulled the motor in my '90 Burb (w/3.42's, 35's and a 700R4) the trans fluid looked very dark. I never put it in OD, and still burnt the fluid....
