give this a look
Discussion in 'The Garage' started by aknight_sa, Nov 20, 2006.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    these are pics of my roachster q-jet carb on my bb engine
    anyone see any problems in the vacuum hoses on this carb?
    http://pg.photos.yahoo.com/ph/aknight_sa/detail?.dir=1185&.dnm=8684scd.jpg
    in the next pic... what is the difference between the two vacuum ports highlited?
    http://pg.photos.yahoo.com/ph/aknight_sa/detail?.dir=/1185&.dnm=94e7scd.jpg
    in the next pic, what is this port on the intake for???
    http://pg.photos.yahoo.com/ph/aknight_sa/detail?.dir=/1185&.dnm=e0dbscd.jpg
    thanks
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    The last pic is a thermostatically controlled vacuum switch.
    I believe its for EGR function.
    Don't know on the first two.
    I have my distributor hooked to the vacuum port closest to the fuel inlet.
    Not sure if it makes a difference.
  3. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    if its the EGR... should it be connected somewhere to the carb?
    any help on the second pic?
  4. Goose
    1,127
    Ref the dist. vacuum advance hookup. The main thing is it needs to be a 'ported' vacuum. Meaning it only gets vacuum depending on how wide open the carb is as opposed to the vacuum running to the brake diaphram that has full vacuum.
    It looks like your missing a bunch of the other emissions vacuum lines and t-fitting and stuff so I wouldn't worry about the thermo swithc being hooked up.
    The two vacuum ports you circled would have a lot more vacuum hoses connected if all the emissions was still working.
    Since all of it is tied together (mostly via vacuum hoses), you can't just hook the EGR back up.
    Short answer is don't worry about it unless you have smog laws.
  5. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    what about the missing vacuum lines?? what are they? and what do i connect them to??
