glad to be a member again, 4" spring questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by alaskanbowtie, Feb 15, 2004.
  1. alaskanbowtie
    alaskanbowtie 1/2 ton status
    Feb 15, 2004
    112
    ALASKA
    glad to be a member again, 4\" spring questions
    I have a donor set of rear 52", 4" EZ-ride springs and am wondering if I put these in the front of a blazer how much lift will it give me? I'm not sure if the locating pin is in the same place on the pack as a front set? I would like to take the 1 short leaf off the bottom of the pack and then put them on the front hopefully giving me around 6" of lift. I figure they will be a bit stiffer but I can except that. THX everyone glad to be back I was formerly twenty_below0 . /forums/images/graemlins/thumb.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: glad to be a member again, 4\" spring questions
    zcarzcar put stock 52s up front and he got 4 inches of lift. actually he got about 5 inches but he has a 2inch longer front shackle. so with 4" springs you should ge about 8" lift. the axle will be located 2 inches foward than stock,but you could re drill the spring perch to make it fit /forums/images/graemlins/waytogo.gif. he said that it was extremely smooth /forums/images/graemlins/bow.gif
    i plan on doing this swap with the ak-57 rear setup /forums/images/graemlins/woot.gif
    welcome back /forums/images/graemlins/waytogo.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I put a set of 4" lift 52" BDS springs in the front of my blazer. With the overload spring removed and the weight of my big block, i gained 3 1/2".
  4. alaskanbowtie
    Feb 15, 2004
    112
    ALASKA
    WOW, perhaps i could remove even another leaf to get the 6" I want, that should make it really smooth. WOW I'm liking this, move the axle forward 2" is ok as long as nothing else will be effected(other than the drag link, and D shaft) actually 1" would be ideal /forums/images/graemlins/grin.gif
  5. alaskanbowtie
    Feb 15, 2004
    112
    ALASKA
    rear bds springs? & 3 1/2 inches total or you mean more ? (to equal 7 1/2" total ?)
