Glove Box Chart?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WakeBoard&4X4er, Aug 22, 2000.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Does any one know what all the different # in the golve box mean. I know you can tell what gears you have in you diff (if still factory). Does any one out there have a KEY to all the #s or know a sight that i can go to check that out?
  2. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    What year Blazer do you have, I have an 86 and next to all the codes is a decription on mine, however anything that is 87 and up does not have a description, only codes. There are so many of them to just list them all, or to even know them all. I have a verry loaded blazer I also have the RPO (Thats what they are caled) sheet out of a 79, so I have definitions to most of the codes. Why dont you post all of your codes, and if I know them I will tell you what each one of them means. That is easier for me or anyone else who might reply to this post to reply to than just listing them all becuase there are so many. Thanks
    Ike
    Jeep, what every boy dreams of... K5 what every man owns!!!
  3. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    the blazer that i have is a 91 and i think it is fully loaded also. However i will write them down and post them ASAP.
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I've wondered that about mine also. The only ones I figured out is I have 3.42 gears and a Gov-Loc.
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  5. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Here are all my codes, if anyone know what they mean, please let me know.
    1GNEV18K6 MF110872 106.5
    AD5 AJ1 AK6 AM7 AQ9 AU3 AXP A31 BB5 BC3 B30 B32 B33 B85 B96
    CMD C5M C60 D48 GU6 JB5 K34 K60 L05 MD8 MX0 NA5 NK3 NY1 NY7
    N33 N90 P17 R8T SLM TR9 TT4 UN9 UP8 UX1 U73 VE5 VG3 VX5 V02 V22
    V73 X0Z X6Z X88 YD3 YD5 YD6 YE9 YG3 YUZ EQ2 EQ3 ZUZ ZW9 Z41
    Z75 1SE 1SZ 12K 471 50U
    WAEM WAL8624 V862447D ORDER 589W4R
    Thanks all
    this is a 1991
  6. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
  7. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    Go by Albright Cheverolet in Grandview,MO(South KC Area)and give them your VIN and they can give you a print out of your options. This can only be done for vehicle less than 10 years old or e-mail me and I can look them up in my code book.
  8. 87Blzr
    87Blzr 1/2 ton status
    May 24, 2000
    111
    AD5 AD5 WINDOW, SIDE RR SLIDING
    AJ1 WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
    AK6
    AM7 SEAT, RR, FLDG
    AQ9 SEAT, FRT BKT PASS DRIVER RECL
    AU3 LOCK CONTROL, SIDE DR, ELEC
    AXP
    A31 WINDOW, POWER OPERATED, SIDE
    BB5 ORNAMENTATION, INTR, HEADLINER
    BC3 ORNAMENTATION, INTR, I/P, DELUXE
    B30 COVERING, FLOOR CARPET
    B32 COVERING, FRT FLOOR MATS AUX
    B33 COVERING, REAR FLOOR MATS AUX
    B85 ORNAMENTATION, EXTR MLDG BELT REVEAL
    B96 MOLDING WHL OPENING
    CMD
    C5M
    C60 HVAC SYSTEM, AIR CONDITIONING FRT MAN CONTROLS
    D48 MIRROR O/S, REM CONT, ELEC PAINTED
    GU6 AXLE REAR, 3.42 RATIO
    JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
    K34 CRUISE CONTROL, AUTOMATIC, ELECTRONIC
    K60 GENERATOR, 100 AMP
    L05
    MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
    MX0 MERCHANDISED TRANS, AUTO PROVISIONS, O/D
    NA5 EMISSION SYSTEM, FEDERAL TIER 0
    NK3 STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
    NY1 SHIELD, FUEL TANK
    NY7 SHIELD, TRANSFER CASE
    N33 STEERING COLUMN, TILT TYPE
    N90 WHEEL, 15 X 7, CAST ALUMINUM, 4.75 INCH BOLT CIRCLE
    P17 COVER SPARE, WHEEL
    R8T
    SLM
    TR9 LAMP, GROUP
    TT4 HEADLAMPS, HALOGEN, 4
    UN9 RADIO, SUPPRESSION EQUIPMENT
    UP8
    UX1
    U73 ANTENNA, FIXED, RADIO
    VE5 BUMPER, FRT & RR, IMPACT, CHROME
    VG3 BUMPER, FRT, IMPACT STRIP
    VX5
    V02 RADIATOR, HEAVY DUTY, WITH TRANS OIL COOLER
    V22 GRILLE, CHROME, RADIATOR
    V73
    X0Z
    X6Z HUB, LOCKING AUTOMATIC
    X88 CONVERSION NAME PLT CHEVROLET
    YD3
    YD5
    YD6
    YE9 CONVENIENCE PKG, COMFORT & DECOR LEVEL #3
    YG3 ORNAMENTATION, BODY SIDE 6 WHL OPENING BRIGHT
    YUZ
    EQ2
    EQ3
    ZUZ
    ZW9 BODY EQUIPMENT, BASE BODY OR CHASSIS
    Z41
    Z75
    1SE
    1SZ
    12K AUX TOP COLOR WHITE (91)
    471 INTERIOR TRIM, DK RED (I) (91) if its 47I and not 471
    50U PRIMARY COLOR, EXTERIOR, BLUE WHITE (91)
    here are your codes, the blank ones either I don't have on this list or they are misprints
    This is from a old RPO list. I have a updated one but can't find it at this moment which may have the missing codes
    87 K5 Siverado, 68 SS 396 Camaro
  9. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Called chevy and they are send me all the info on my truck. Thanks for alllllllll thhhhhheeeee HHHHEEELLLLPPPPPPP
    Big Cox
  10. 86blazerk5
    Aug 9, 2000
    387
    Vin Number de-code
    1GNEV18K6 MF 110872
    1=US
    GN=Chevrolet
    E=6001-7000 Hydrolic GVWR Rangen Brake System
    V=4 Wheel Drive 1987-91
    1=1/2 ton
    8=Body Type, Utility
    K=350 V8
    6=Check Didget
    M=1991
    F=Plant Code, Flint Michigan
    110872=Production Sequence
    106.5=Wheel Base
