glove box codes
Discussion in 'The Garage' started by 78Suburban, Aug 26, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    everyone on here says to look in the glovebox at the code panel.. am I missing something? my glove box just has like some kinda plastic liner and that's it.. I wanted to see if the gov-80 bomb code was on mine, but don't see the panel? where is it supposed to be in the glove box?
  2. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Its normally a white sticker on the plastic inside the glove box. You'll be lucky if its readable, or even there in your 78
  3. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    Not always..
    The RPO codes listing isn't always in the glove box(69-72 GM trucks had them inside the glove box door)--most 73-87 GM trucks have the code sheet laminated in plastic,and they glue them to the drivers side inner fender...not many survive there more than 5 years or so... I've found some "build sheets" under the seat,tucked between the springs and the padding on a few trucks..that might still be there if the seat's original,and the other "list" is gone...
    One day long ago I was under my van,changing the oil--I noticed a factory hole in the unibody rail,it had a peice of paper in it!--at first I thought it was MONEY!! :laugh: --but after I spent 15 minites digging peices of it out,I was able to read it--it wasn't money :doah: :frown1: --it was the RPO code sheet--evidently someone stuffed it inside the boxed frame rail!! :mad: :crazy:
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine is an 87 and it is inside the glovebox on the door just in front of the little pocket on the drivers side of the glovebox. Since it is inside the glovebox it is protected and is style quite legible.
    Ira
  5. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    In the frame rail?!? That's crazy!
  6. dyeager535
    26,980
    They obviously changed the sticker location in the mid-80's. My '83 was on the fender, every year after that I've seen has had them in the glovebox.
  7. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    To find this RPO sheet in the fender would I open the hood?
  8. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    Yup.
    Yes--under the hood,on the inner drivers side fender..IF its still there!..as Dorian said,they started putting them in the glove box during the 80's..as were the 72 and older ones!..Why didn't they just KEEP putting them there?? :rolleyes: :crazy:
  9. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    My 78 has the RPO code sheet in the glove box. The emmisions decal is under the hood. Never heard of RPO code sheets under the hood before.
  10. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    on my 89 burb scotsdale 6.2 it is in the glovebox. the "rpo" codes are the 3 letter/# things right? where do you decode that at anyway?
  11. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    Great question. I'm not sure of any source. However on the RPO build sheet it has the codes then the description to the right of the code.
    It would be great to have a collection of all codes by year. This would be all the codes for all options along with descriptions. Maybe people could add there codes and the forum could build a collection.
  12. sandawgk5
    Oct 28, 2003
    6,881
    It has already been done here
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    uhhm they were all on glovebox in all the trucks thative owned 67-87 all cept a few 82 83 trucks, and ive owned and looked at a TON of trucks in the last eleven years,
    all my 73-80 trucks RPO lables have been on glovebox lid
    ALL of them
    never under hood
    janesville and st louis plants
    on trucks 87 up the sticker only has the codes and no descriptions and the sticker size decreased by alot,
    i dunno about otherr plants like in GA and cali and such, who knows where they put the label in thosae plants as ive never had a truck from any plants other than st louis and janesville
    it must depend on year and plant
    i bet you it does.,
    if you dont have one on glovebox lid or under hood on wheel tub then its gone someone peeled it off, they are easy to peel off, from 73 to 87 anyways
    67-72 and 87 up are impossible to peel, will ruin them they are real thin and glued on, just like in the cars(84 is the first car spid label and most all of them are glued to underside of the trunk deck on rwd cars, and to the spare wheel cardboard trunk floor cover panel on FWD cars) car oens list no RPO descriptions either and are smaller like the car ones,
    the vans were stuck to uidnerside of hood most always on driver side and were same as the 73-86 truck ones with descriptions and all, though 86 probably like the trucks im sure
  14. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    plant locations??
    About 90% of all the trucks I see in my area and that I've owned were all made in Canada! :eek1: --they all have a maple leaf sticker on the door frame!..either that or the Tarrytown NY plant..I've seen very few trucks from other assembly plants--only one from TX,and another from MI..must be they ship trucks to the closest area to the plant..only makes sense not to ship them 1000+ miles!..they probably DO have different places to put the RPO sheet at different plants.. :confused: :crazy:
