Glove box codes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Mar 9, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    I took a look at my glove box in my 89 jimmy and noticed there were a bunch of factory codes, my buddy told me that they are all options codes. Can anyone send me to a website or something that tells me what these codes mean. Thanks /forums/images/graemlins/k5.gif
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    We have a complete list of the RPO codes in the Bloody Knuckle- all you gotta do is buy a membership to gain access. There's loads of other goodies in there too.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    use google.com or yahoo search bar which is also google now use keyword RPO with each code too. or list soem or all of them in a reply to this thread, many of us can find out what all or most of them are
    good luck
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Do a search. They're regular production option codes. I keep my list at www.wrath.com/rpo/.
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    GU1 I think it is a 2.42 or 2.43 Thanks
  6. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Less than 2.73 was never used in a truck to my knowledge. They were pretty common in Impalas and other large cars (especially the bigblock Cadillacs) of the 70s though.
  7. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    My 88 sub with 10 bolts has that. GU1 with a 2.42 or 2.43 ratio. It sucks. I've got 4.10 for the rear axle waiting for nicer weather. I need 4x4 till the snow melts. Can't find a front axle around here. /forums/images/graemlins/burb.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    gu1 is 2.41 car ratio. commonly found in 7.5" 10 bolt which is car axle, 2.73 and up is what truck(8.5") got in them
  9. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    I think you probably have 2.73 still but that's bad enough. Even taller gears would suck more than anything had ever sucked before. I have 2.73s and they blow donkeys in July. Even though I have a 305 that scares most mild 350s my truck can barely even get out of its own way. I can't imagine adding a couple thousand more pounds and then try driving it around.
    I have a pair of 3.42s that are going under mine. I couldn't find 3.73s or 4.10s so I guess I'll settle for 3.42. It should help a little.
  10. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    The GU1 is what i've got. Does that mean I have a 7.5" ring gear? I Overhauled the axle last year and sure enough it was a 2.41 I don't remember what the numbers were but I divided the ring teeth by pinion teeth and came up with 2.42 on calculator. I looked in the glove box last night and it said GU1. I think the truck has a factory tow package too, so go figure? /forums/images/graemlins/burb.gif
  11. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    This is the only code numbers I have in my glove box.
    1 C 8 E K 1 8 C O D F 1 5 9 6 8 3
    Any help decipering this number? Seems this my vin number.
    No other numbers are there.
    Just trying to figure out what gear I have in my 10 bolts.
    Thanks. /forums/images/graemlins/k5.gif
