Glove box latch removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MUD_SPEC, Apr 24, 2001.
  1. MUD_SPEC
    MUD_SPEC Registered Member
    Apr 10, 2001
    49
    I'm painting the interior of my '83 and I can't find out how to remove the glove box latch. It's not the locking type and it has a very small hole in the front and it looks like some kind of slide grooves on the back (like the back half turns somehow).
    Can anyone tell me how to get this thing apart. Thanks.
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    12 lb. sledge and a pry bar... What happens if you stick a paper clip in that hole, it might press a release of some kind...
  3. MUD_SPEC
    Apr 10, 2001
    49
    WOW!! 12 lb sledge!!?? I'm trying to stay away from bodywork :-) I stuck a paper clip in the hole and wiggled it, but I couldn't get it to release anything.
  4. dyeager535
    26,982
    191
    It has something to do with the paper clip in the hole, then with the clip in there, try to open it normally. I can never remember exactly how to do it, I just play with it until it falls apart.
    Dorian
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Why don't you just put some masking tape over it? When yer done it pulls right off....
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Cause its funner to take things apart DUH, And sometimes if your real lucky you have extra pieces left over, I have all kinds of extra pieces now and maybe some day I'll have enough to put together an extra blazer... WOOOHOOO!!!
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    Mudspec you figger it out yet, man I love to type in redneck,
  8. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Hey...I post my response to help this guy with what I did because it was quick and easy when I painted my rig....and you reply to me with duh? What's that about? If you don't like my suggestion ignore it, don't put me down!! [​IMG]
  9. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Ya, put a smiley after a "duh" if you are joking and nobody gets mad...like this [​IMG] cause then we know you're joking (if you are and I sure hope so or I will be [​IMG]). See, you can't get mad at a smiley. "Duh's" are not good ways to make freinds on here. Enought with the "duh's" already.
    I for one would like to know how to make those bastards tighter. Mine rattles like crazy!
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  10. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Open the box and trip the latch like the box was closed, just inside the box on right is a poke hole. While holding the latch, poke your paper clip in the hole and find a wafer that is spring loaded and push it in while prying on the lock face on the glove door with a small flat blade. The lock will pop out enough so you'll see another wafer to push on while pulling on the lock and it will come out. Just check the angle of the back so it'll go back in the correct position. Hold the latch like it's locked to slide it back in, while pushing on the wafers, then unlock box and close it. Piece of cake...
    83K5 Silverado
    What was that bump?
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
    Settle down Ladies, no disrespect intended[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG],do ya forgive me now, I'm sorry
  12. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Ok....just thought something else is all.....forgiven....
  13. StoneyK5
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Hey MUD SPEC, did ya figure it out ? It has nothing to do with the hole in the front of the box (or tape if you want to do it right)....
    83K5 Silverado
    What was that bump?
  14. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    Poster: chevyfumes
    Subject: Re: Glove box latch removal
    LMFAO OMFG HAHAHAHAHAHAHAHAHAHA ok im done here :)
    One From None
  15. chevyfumes
    Feb 24, 2000
    38,584
    266
    See I thought it was funny I never mean to be rude or nasty just makin' jokes thanks ,lowlevell
  16. lowlevell
    Jun 27, 2000
    343
    Central Ohio, USA
    I just came into work and re-read this again....still LMFAO :) Best laugh ive had in days Thanks man:) I probably have enough parts left over to make a TaSubNovaSupraK5XR200.
    One From None
