Glovebox data sheet
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grtwhite, Oct 19, 2004.
  1. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    The data sheet in the glove box, is there a code or does it say if the rear axle had a posi? Looking for a 14 bolt posi at a junkyard thought there might be a quick way of telling if the truck had a posi, instead of hoping underneath and checking for an axle ratio tag. At this yard the vehicles are sitting on the ground so just roating the tire is not an option. Thanks!!! /forums/images/graemlins/thumb.gif
  2. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    g80 is the code for locking rear diff. my parts truck was a 1974 and it said locking rear differential
  3. grtwhite
    Aug 3, 2000
    366
    Macungie, PA
    Sweet! Thanks for the fast reply /forums/images/graemlins/waytogo.gif
  4. dyeager535
    26,979
    Rotating a tire won't work (well, if you spin it fast enough it can) with a gov-lock anyways (G80 for most trucks) so you aren't missing out there. /forums/images/graemlins/smile.gif
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Sometimes, the rpo sheet is on the fender well. Look there too...
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    takes 100 rpm spin of one axel to make gov lok unit lock shafts,
    you wouldnmt want a gov lok axle anyways
    good luck
  7. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Which fenderwell? Where? I have no sheet in my glovebox and figured the PO must have taken it off!
  8. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Little late, but isn't it GT80? I could be wrong.
    If it is on the fenderwell you'll see it on top of the fenderwell when you pop the hood. I think it's on the passenger side.
  9. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
  10. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    IIRC, I have seen them on the drivers side. I see lots of them at junk yards but I am not 100% sure what side it is on.
    Better check both side /forums/images/graemlins/smile.gif
