Glovebox Lock Removal (89' Burb)?
Discussion in 'The Garage' started by AZ_Overdrive, Feb 7, 2004.
  1. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    Glovebox Lock Removal (89\' Burb)?
    OK, Search turned up nothing...
    How in the heck do you take the glovebox lock apart? I messed with it for about an hour but cannot figure it out! It's one without a key...
    Any assistance would be appreciated.
    Thanks!
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: Glovebox Lock Removal (89\' Burb)?
    You have to stick a paper clip or similar into the hole and turn it. I don't recall the specifics, but you put it in and turn it, or turn it and put it in, something like that. Just fiddle around with it, you’ll get it…
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    B F H /forums/images/graemlins/tongue.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Stick a paper clip in the hole in the chrome piece. Holding it in there (may have to jiggle it around) turn the back piece. The chrome piece will eventually pull out. Then unscrew from that threaded piece you see. Install is reverse.
  5. AZ_Overdrive
    Dec 18, 2002
    117
    Arizona
    Got it! Thanks.
