Glow plug article at TheDieselPage.com
Discussion in '1982-Present GM Diesel' started by Danno, Feb 19, 2002.
  1. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    <a target="_blank" href=http://www.62-65-dieselpage.com/reviews/02GlowPlugs.htm>http://www.62-65-dieselpage.com/reviews/02GlowPlugs.htm</a>
    For those of you who are interested in this sort of thing, they talk about the AC-60G glow plugs, and the Kennedy's "Quick-Heat" plugs. Nice pictures of the two as they heat up during one of their tests.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  2. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    In a somewhat related topic... For those who are interested, my manual setup with the 60Gs is still working perfectly after a month. The truck starts happily now, even if the temp is in the single digits all night and the heater is not plugged in. In fact, I don't even plug it in anymore...
    <font color=red>When in doubt, empty the magazine. </font color=red>
    <a target="_blank" href=http://www.geocities.com/calcide>http://www.geocities.com/calcide</a>
    1983 K5 Blazer Silverado, 6.2L Diesel
  3. Danno
    Aug 4, 2001
    487
    Rockford, IL
    I can report the same thing. I switched to AC-60Gs a while back when I was having starting problems.
    I never plug the truck in, and it starts easily now. I also have a manual GP system, but hopefully I'll get the newer style controller this summer and get rid of the manual only system.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How do you setup the manual switch? My glow plug contoller works fine when the engine is cold, but when it is bearly warm the gp's don't come on, I have to short out the relay.
    Houston, TX
    <a target="_blank" href=http://community.webshots.com/user/cegusman>http://community.webshots.com/user/cegusman</a>
  5. Danno
    Aug 4, 2001
    487
    Rockford, IL
    That's pretty much what the manual GP system is. I've got a bad controller, and the previous owner never fixed it. I bought the truck with a push button on the dash for the GPs.
    I'm going to fix that, though.
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What type of push botton is it, I know it has to be able to handle some power.
    Houston, TX
  7. calcide
    Dec 21, 2001
    283
    I used a ford starter solenoid to replace the stock relay and then a push-button switch zip tied to my steering column to switch the solenoid. The switch doesn't have to handle a lot of current, the relay does that. Total cost was under $10. I have a more detailed description in the thread for the message "Cold starting problems..."
  8. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I believe you can use a normal 12 volt switch to energize the relay.
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
