Glow plug question ??
Discussion in '1982-Present GM Diesel' started by 6.2 man, Sep 26, 2004.
  1. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Friday night my Blazer wouldn't start . So when I was cranking I was getting smoke so I know I have fuel . So then I checked my glowplug wiring and juice was going to those . So I figure my Glow plugs are bad . Been hard starting for about a month or so . So I pulled a glow plug and hooked it up to a 40 amp charger and no heat ? Is there another way to check them or is that a good way ?
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Try putting an Ohm-meter on them, should have have about 1 ohm between the terminal and the threads. They pull about 200 watts each, so your charger may not give you enough current to test them that way.
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    I test mine in the truck
    i just unhook the green wire
    then hook up your GOOOD QUALITY test light to the positive terminal on the battery then i touch the prong that the green wire plugs onto
    if my test light comes on i know the glow plug is good if it dont it is bad
    simple :-)
    Hope it helps
    R
  4. 6.2 man
    636
    Curtis , WA
    Hey Guys thanks a lot for your help !!!!!Both ways worked great and it's up and running !!!!! /forums/images/graemlins/peace.gif
