Glow Plug Test
Discussion in '1982-Present GM Diesel' started by Dirty Dave, Jan 29, 2002.
  1. Dirty Dave
    Dirty Dave 1/2 ton status
    Dec 21, 2001
    101
    Kentucky
    Can someone explain to me in the simplest of terms how to test a glow plug to see if it is working. I thought I knew how but since I can't get any of mine to work I think/hope I was wrong.
    Thanks,
    Dave
    They call me Dirty Dave because thats the way I fight. At my age I cant afford to fight fair
    It's just mud how deep can it be?
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Simplest: resistance. Use an Ohmeter to measure resistance from the connector on the end to the threaded portion on the plug. 'Can't remember what the actual value is, but is may vary depending on your plugs (9G, 11G, 13G, 60G?). Infinit resistance means they're bad, zero resistance would be suspect. You can do this on the vehicle but it's a PITA. Usually if I suspect bad plugs I'll check 'til I find a bad one, then replace them ALL. Theory being that they're all similar age so the others (good still) aren't that far behind.
    PS. I always check NEW glow plugs before installing, but then I deal with the DOD's "lowest bidder" philosophy.
    Real trucks don't have spark plugs!
  3. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I would have to say the easiest way to test a glow plug is to get a test light... first get a good ground then unplug a glowplug wire, touch the pointed end with the light on the end of the glowplug if the light goes on the glow plug is good.. if you need farther explanation feel free to ask.
    Sergio
    Check out my new website. <a target="_blank" href=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</a>
  4. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    If you haven,t a test light, you also can to test it with a wire.
    Connect the wire to the positive battery harness.Then remove the harnnes attached to the plug.Now,with the other extremeof the wire , took a few times the phaston conection on the plug body. If it makes sparks, the plug is good. If not ,is broken.
  5. JORGE
    Jan 10, 2001
    213
    Touch the phastom ,no "took".Sorry.
  6. Parf
    Parf Registered Member
    Nov 16, 2001
    81
    Golden, Colorado
    I like to short them between the top positive post on my battery, and the radiator support. If it glows, it's good. [​IMG]
    <font color=blue>Parf</font color=blue>
    1984 K5 Jimmy 4x4 Sierra Classic
    6.2L diesel, 700R4
  7. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    A resistance check would be a very easy way, each glow plug should have about .8 ohms (I read that 60G plugs draw 15 amps each, making their resistance about .8 ohms) of resistance from the spade connector to ground. To be able to accurately measure this though, you will need a pretty decent multimeter and you should remove the wire going to the plug. I recommend Fluke products.
    The easiest way would be to use a clamp-on ammeter. Just clamp it on and measure the current going through each glow plug. I recommend Fluke and Amprobe products for this, just make sure they can measure DC amps and have a low enough range.
    BTW, that battery/radiator support test is pure genius.[​IMG]
    <font color=red>When in doubt, empty the magazine. </font color=red>
    <a target="_blank" href=http://www.geocities.com/calcide>http://www.geocities.com/calcide</a>
    1983 K5 Blazer Silverado, 6.2L Diesel
  8. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    Parf thats the way I did it...and trying the resistance method I got the same results..all the plugs where toast. Thanks to everyone the search for the cause begins tommorow. First thing is to interrogate my girlfriend since she drove it last time it ran.
    Thanks to all.
    Dave
  9. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    Interrogation has reveiled that she forgot and left the manual switch on for "a little while"
    hmmm, guess now is a good time to work the bugs out of my glowplug system.
    Thanks again everybody.
  10. Terry
    Terry Registered Member
    Feb 21, 2002
    12
    No. Michigan
  11. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    <a target="_blank" href=http://freeautoadvice.com/diesel/glow.html>Clicky</a>
    '80 K5,355/350/205,soon 6.2 diesel swapped in and 33" tires[​IMG]
