Glow plug thread size? Building a compression tester.
Discussion in '1982-Present GM Diesel' started by FWP, Sep 22, 2004.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm going to make my own compression tester, Does anyone know the spec on the glow plug threads? Pitch and Diameter? Thanks.
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    M10 X 1. Maybe a bolt with a hole tapped into it for 1/16 NPT? Or maybe modify a bad glow plug? /forums/images/graemlins/thinking.gif
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    There is a guy on the diesel page who drilled out a glow plug and made a luminosity probe out of it. If he could do that I would think one could be made into a pressure tap.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yup, that's what I was thinking.
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Did the glow plug thing.
    Save your time and just buy the adapter from Matco for $15. The compression gauge and adapter run less than $80 IIRC. Wish I had went that route, would have saved lots of time. I bought my compression gauge from a parts store, don't recall the price. At that time I not even though about Matco, they are much cheaper than Snap-on for the compression gauge.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Ahh, I knew there was someone who went through this already. Thank you sir /forums/images/graemlins/thumb.gif Saved me some brain waves /forums/images/graemlins/histerical.gif
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Harbour freight has a tester now on sale for under $150 and it has all the adapters to cover any diesel on the planet well at least for the Medium duty and down.
    I got mine from napa for $300 and only has a couple adapters. /forums/images/graemlins/dunno.gif
    I think I want to get this one just to have all the adapters.
  8. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Also need to point out that the new adapter I have gives 20-40 psi higher readings. Must have been the converted G/P I used did not have a large enough hole or high enough flowing check valve.
