glow plugs arent glowing...
Discussion in 'The Garage' started by KGsK5, Sep 6, 2006.
  1. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    when i turn my key to accesory mode, when the glow pug light on my dash usually turns on, nothing happens... i thought it was my glow plug relay and i replaced that and it still os doing the same thing. when i turn the key to start, the starter does crank... and also, my dash lights and headlights do work. :confused: :confused: :confused:
  2. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    Could be the glow plug controller, or a bad temp inhibit switch...
    I swapped mine to manual control a while back, just so much easier.
    Rene
  3. KGsK5
    Aug 26, 2006
    343
    you just bypassed the glow plug relay and put a switch on your dash?
  4. KGsK5
    Aug 26, 2006
    343
    alright i did a seach for manual glow plug controllers and found enough info to get me started... ill give it a try tomarow.
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    one way to check to make sure you're getting power so you can jump start your glow plugs is to take the wire coming from the positive battery terminal, and touch it against the terminal on the opposite side of teh controller. if it sparks/turns on, you've got power. definitely switch to the manual set up - reliable and more controllable.
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    If you trace the small blue wire to the controller at the back of the engine...cut it about 6" away from the controller. Then pull it out of the loom and route it to the dash. The energize the GP's that blue wire just needs to be grounded, so you can use a push button switch to accomplish that.
    Upside is you only need to glow as long as is needed...more than what the controller would do or less depending on engine temps. I only use mine to start it cold, after it's even remotely warmed up it'll flash up without the GP's just fine.
    Rene
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    same, i usually end up just using the plugs 1 or 2 times a day
  8. KGsK5
    Aug 26, 2006
    343
    thanks a bunch. ill be doing that tomarow and hopefully will have er runnin by this time tomarow evening.
