Glow plugs dont work
Discussion in 'The Garage' started by stumblefoot, Apr 8, 2007.
  1. stumblefoot
    stumblefoot Registered Member
    Nov 25, 2006
    20
    Copperas Cove TX
    Went to start the Blazer and my glow plugs dont work! No glow plugs=no start. Its been converted to a push button, no "wait" light. Its an old ARMY CUCV so its a 24V system, when the glow plugs work you can see the voltage drop on the gauge. The solinoid works OK, but no voltage drop, and no glow plugs, is there a fuse or something I am missing? Im stumped, and its my DD so I kinda need it fixed soon!
    84 K5 Blazer 6.2L diesel TH400/NP208 4" lift on 35" Pro Comp Xtremes 4:10 gears with detroit lockers front & rear.
    I just put new glow plugs and injectors in it and had the injector pump rebuilt.
  2. stumblefoot
    Nov 25, 2006
    20
    Copperas Cove TX
    bump, need some advise
  3. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I would check the ground on your push button first. Have you traced your wires yet? Power in and out of your solinoid? Check the output on your resistor bank (drops the 24v to 12v), it could have taken a crap. Then start checking each GP. If one goes it will send higher voltage to the others until they fry.
  4. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    yep, make sure all your wires are hooked up first. had the same problem on mine, ended up being a wire I had knocked loose when i was doing some other work on it.
  5. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    IIRC there are fusible links in the GP wires. You may need to check for continuity between the GP lead and the solenoid, and between the solenoid and the battery. That is, unless you have replaced all the original GP wiring...
