Glow plugs won't turn on
Discussion in '1982-Present GM Diesel' started by cegusman, Dec 15, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Glow plugs won\'t turn on
    My glow plugs come on fine when the truck is cold, but when it is just barely warm thay don't come on at all ( It is not warm enough to start without the glow plugs). I can start the truck if I bypass the the relay and get them to cycle. I have allready replaced the relay and the glow pugs are good, What else sould I consider looking at or replacing?
    Houston, TX
  2. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Re: Glow plugs won\'t turn on
    I guess this is a fairly common problem with the early diesels like ours. One solution is to convert to the newer style glow plug controller, and relocate it. There's a writeup on http://www.thedieselpage.com (have to be a member to read it) that explains how to do the conversion to the newer style glow plug controller.
    I'm going to do this very soon, and I'll report back on how it goes.
    Anyone here already done this conversion?
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  3. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    I'm not sure that did I have this newer style controller on my C-10,but it had same problem.Glow plugs would not cycle if engine was warm enough.My sollution was to bypass the temperature sensor with switch,so when I was sure that glow plugs won't cycle,I just flip the switch,let the gp light go on once and started the engine.
    Controller was a small,grey box that was bolted on the back of the left head.It has row of small connectors on top of it and two bigger connectors were the +12 and glow plugs were connected.Was it the newer style controller?
    I'm too lazy to stick shift,that's why I prefer autotranny.
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I don't have a membership to the diesel page and can't afford it right now. Can someone with a mebership post the writeup?
    Houston, TX
  5. Danno
    Aug 4, 2001
    487
    Rockford, IL
    The easiest way to tell if you're using the old GP system vs. the newer one is to find out if you have a seperate GP relay. If you have a relay, you're using the older system. The newer GP controller has the relay built into it.
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    The grey gox is the newer controller
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  7. braunm
    braunm Registered Member
    May 26, 2001
    77
    I was told that they did not need to cycle when it is warm?
    Mike
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have the old style, Is the only other main part the glow plug controller, or is there a temp sensor?
    Houston, TX
  9. Danno
    Aug 4, 2001
    487
    Rockford, IL
    I believe there's a temp sensor inside the GP controller.
