Glow Plugs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stainlessrat, Oct 28, 2001.
  1. Stainlessrat
    Stainlessrat Newbie
    Oct 22, 2001
    4
    So Cal
    Glow plugs do not come on. That's the short of it, here's the long... I just replaced the starter on my '83, but now the glow plugs aren't lighting up. Once started I have no problems because it's warm. Any Ideas?
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Is your glow plug relay clicking ? Thats the thing that looks like a Ford starter solenoid on the drivers fender ?
    1990 K5 4" lift, 33's, 3.73's Raptor Tranny and Velvet Rides....
  3. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I would say check the relay and the controler it is located near the firewall, a little toward the drivers side, behind the air cleaner. You could also put on a manual switch, mine had one when I got it and I can't even count the number of times the manual switch has saved me when my plugs didn't want to come on. They will cycle after it is already started but not till after i use my manual switch to turn them on and get the engine going?? I don't understand it.
    Sergio
    Check out my new website. <a target="_blank" href=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</a>
  4. Stainlessrat
    Stainlessrat Newbie
    Oct 22, 2001
    4
    So Cal
    Thanks for the information. Yeah, I think I'm going to put a manual switch in... just in case. Another note, the glow plug relay is not clicking over.... does that mean I need to replace it? One "learning experiance" after another. Got to love it.
    Stainlessrat
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Jump the (smaller) controlling wires on the relay/solenoid and see if it clicks/powers-up now. If it doesn't your relay is dead. If it does you've got a problem elsewhere: controller circuit or temp switch. I think the early Controllers used small relay contacts in it, a potential trouble spot.
    Hey we need to move this thread to the Diesel Forum lest we anger the spark-heads.
    Real trucks don't have spark plugs!
  6. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    I had the same problem. All I needed was a new temperature sensor.
