gm 10 bolt, 3/4 ton????
Discussion in 'The Garage' started by CRAZEDHICK3, Jul 26, 2002.
  1. CRAZEDHICK3
    CRAZEDHICK3 Registered Member
    Feb 14, 2002
    6
    Virginia
    Is there such a thing as a gm 10 bolt, 6 lug, but its a 3/4 ton. i am in the middle of putting a 6 inch suspension lift on my 90 jimmy, but items such as tie rod across the front only matches up with 3/4 ton listings. and when i dropped the rear axle for the spring install, the u-bolts were too small. the axle tubes measure 3 1/8" but the 1/2 ton u-bolts are 2 3/4". anyone else come across this?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Oops! Your 2 3/4" u-bolts are the "first design" axle u-bolts. This means the u-bolts you have fit the '76 and older front axles. /forums/images/icons/tongue.gif
    You need to swap those u-bolts for the newer "second design" axles which are '77 on up. /forums/images/icons/wink.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    As far as I know, 3/4 tons only came with 8 lugs and 1/2 tons with 6 lugs. Correct me if I'm wrong someone.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    u r right muddytaz.3/4 is 8 lug and 1/2 is 6 lug.always was like that as far as i know
