GM 10 bolt and 35's
Discussion in 'The Garage' started by guest, Oct 9, 2003.
  1. guest
    guest Registered Member
    Aug 18, 2002
    41
    GM 10 bolt and 35\'s
    Will a Gm 10 bolt be alright for 35's? or should i stick wih 33's?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Re: GM 10 bolt and 35\'s
    It depends on how hard you are wih it. Locked or Open? If it's locked it's probably not a matter of "if" but "when" it will let go. If you are mainly running on the streets with occasional off-roading run it until you start breaking parts. You will get many varied opinions on here about the 10 bolt. Mostly bad, but they are a pretty weak axle. Try a search for "10 bolt rear" prolly find some good carnage pics /forums/images/graemlins/thumb.gif
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Front or rear?
    If its front and your not EXTREMELY hard on it then I think you will be fine...
    Rear if its a gov-lock then I highly dought it(or anyother locker) Open you might get aways with it for a wile but adventually you will want a locker if your doing any offroading, You may want to figure out now what you want to do with this project a 14bolt FF would be great or even a 14bolt SF would be better, But unless you want to dump alot of $$$ into that 10bolt I would say no unless you drive mostly on the street and its open...
  4. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    It really depends on how you drive. An open 10 bolt rear diff. should be OK with 35's as long as you don't drive it to hard. I'm sure you will get a lot of people saying buy a 14 bolt which is basically bulletproof but a 10 bolt is OK for street driving and mild wheeling.
  5. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Everyone says that a 10 bolt is about on par with a D44. I have seen numerous vehicles wheeling with 35"+ tires and D44's with no problems.
    So, if 10b's are on par with d44's, you should be fine.
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    How many of those vehicles weighed 5000+ lbs though??
  7. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    True, most were in the 3.5 to 4K range.
  8. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    simple answer: 35s on a 10-bolt front = decent combo... 35s on a 10-bolt rear = breakage waiting to happen. Semi-floating + heavy as hell rig + c-clip design + bigger than stock tires adds up to eventual breakage. If its just a street rig, sure np, run 35s... but if you wheel it, its only a matter of time before a rear 10 bolt shaft lets go and your tire/wheel go on their own offroad adventure without you. /forums/images/graemlins/grin.gif
    j
  9. guest
    Aug 18, 2002
    41
    Well, does any one here run a 10 bolt with 33's or 35's? Had any problems? And what about a 12 bolt rear? would that not be risking it?
  10. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    I run a 10 bolt... Well, at least it runs in my driveway. /forums/images/graemlins/grin.gif
    That's where the truck will sit until I complete the rebuild and installation of my recently aquired 14bff and D60... /forums/images/graemlins/thumb.gif
    Gov-Lock went tick... tick... BOOM!
  11. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    dont bother swapping in a 12 bolt... ff14b are DIRT cheap and so much better in so many ways its not even funny. U can even keep ur 6-lug rims if u use wheel spacer/adapters...
    j
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree. 12 bolt is trash, just as weak as a 10 bolt in most places and weaker in others. Mine broke just as easy as a 10 bolt. 14 bolt has been holding strong for over 2 years now.
  13. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i had a 10 bolt and 33s for a while....not for long...gave it hell across some empty lanes once and it went out nice...was govlocked, broke the carrier....now i have a 12 bolt open and i wouldnt have gone 12 bolt except i needed 6 lug...and got it cheap..
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Classic question. /forums/images/graemlins/grin.gif I have 35" boggers with a 3/4ton front 10B and haven't had any problems. I haven't had it in for long but I have already put it to the test and it didn't break. I think you will be fine as the front goes, mine seems OK with 35" boggers which are much heavier and hook better than say a BFG mt or something plus I have a little bit of horsepower pushing it. I have a rear 14FF and would strongly urge to upgrade the rear to a 14B ff or SF. Forget the 12 bolt. I have seen a few guys run a 10b front and 6 lug 14BSF, all 6 lug and that seems like a good upgrade as far as simplicity and money is concerned.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Front is no big deal. I have a 10 bolt front and 38s right now. At least when the shaft snaps it doesn't take the tire off with it in the front.
  16. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    I run a D44 front and 12 bolt rear. Just check out my webshots and it should answer any questions about running 1/2 ton gear and 35" tires.
    Like stated above, it's all bout the skinny right pedal and gears.
    I love this discussion.
    /forums/images/graemlins/rotfl.gif
  17. guest
    Aug 18, 2002
    41
    ok kool thanks for the info! This always helps me so much. But one more thing- I called my local junck yard they have a 14 bolt rear for about $130, i want to get the 14 bolt, i read CK5'saxle swap, and im probly gonna do it, but the question is can i still use my 15 inch rims with the 14 bolt?
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, you can use your 15" wheels no matter what Chevy axles you use. You can even do so without grinding a 14 bolt full floater.
  19. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It has to be an 8 lug rim if you have a 14B 8 lugger. My guess is you found a SF14bolt 6 lug, good choice if thats it. /forums/images/graemlins/thumb.gif
  20. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I would probably still be runnin a 10 bolt rear if I didnt get such a good deal on my current axles. My take on it is get a good quality ring and pinion and either a selectable locker like an ARB or an Electrac from Eaton or get a Detroit. Stock carriers are junk, aftermarket carriers usually are of a much better design. Hell I've seen 10 bolts hold up to 40" TSL's, not saying that I would do that, but it has and can be done.
