GM 10 bolt vs. D44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudbogAD, Jul 12, 2001.
  1. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    What is actually stronger, a 10 bolt or a D44?
    Adam,
    79' Jimmy, 35" Big O MT's, 350, NP205
  2. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Yeah I am pretty sure a D44 is stronger but don't know why cuz i still got a 10 bolt up front.
    Stuck? Isn't that a bird!
    Steve
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    From everything I have heard or been told there is not much of a difference between the two of them.
    <font color=blue>Wayne<font color=blue>
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Dana 44's have a slightly stronger housing, but are pretty much equal in every other aspect.
    <font color=red>What would Brian Boitano Do?</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  5. dyeager535
    26,982
    191
    I agree with others, I really haven't heard much difference between the twos. One + I have heard on the 10 bolt is a larger pinion over the 44.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI Dana(Spicer) did not build the GM 10 Bolt. NEVER !
    Provide me with a sample of both, and I'll test them for ya.
  7. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    All things considered, in the end they are the same in strength and it would not be worth swapping one over the other (in terms of strength).
    <A target="_blank" HREF=http://www.chriswhitley.com>http://www.chriswhitley.com</A>
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Executioner, I'm missing something here, why write "FYI Dana(Spicer) did not build the GM 10 bolt. NEVER !" he stated that it was a <font color=red>GM</font color=red> 10 bolt while the other was a <font color=red>D</font color=red> (for Dana) 44. Did I miss something here?
    I can usually follow your logic (as some can't), but this one does intrique me.
    And to answer the original question. Both the 10 bolts and D44's have some advantages over one another, and disadvantages over one another. The 28 spline 10 is generally considered weaker than the D44, but the 30 spline 10 is thought (noticed I said thought) to be better than the D44. Either way the differences are pretty much insignificant, if one will break in a given situation, the other one would have too. As far as ring and pinion swaps, the 10 uses carrier shims on the outide of the bearings and the D44 uses them behind the bearings (may mean a little more pressing and unpressing), but other than that it's six of one, half dozen of the other.
    If you didn't build it yourself, how can you call it yours.......?
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    To add to what the others have said, the D44 uses slightly larger carrier bearings.
    Generally the swap isn't worth it unless you are getting better gears or something like that in the D44..
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  10. Executioner
    Feb 22, 2000
    1,530
    Because someone on here continues to post the opposite .
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I recall that being posted...about 10 months ago. I think its time to let it go dude! Are you gonna start another rant about "True duals" again too?
    Rene
  12. Executioner
    Feb 22, 2000
    1,530
    If them are the FACT"s then YES
    P.S, when your in San Deago, let me know would like to show you my 12 Bolt !
    You'll be able to calabrate you eyeball !
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Dude, two things...first off I thought you were in AZ? Secondly are you offering to show me that legendary 12 bolt front axle?
    As long as we're discussing facts how exactly would I know that your front end was a factory offering and not some piece bodgered up by a previous owner. With a machine shop at my disposal I could show you a 14 bolt front end...
    Regardless...I'll pm you from Talldogs place in San Diego.
    Rene
  14. Executioner
    Feb 22, 2000
    1,530
    I am planning on going to San Deigo, its only like 6 hours across the desert !
    Good ? , I don't know what it would take, but I am sure a look and some documentaion may help.
    later
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'm pretty sure we'll be in San Diego on August 6th...
    If you're anywhere close I'd really like to see that front end.
    Rene
  16. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Hmm, to sort of sum up what others have said and what I believe to be true:
    10 bolts do have a larger pinion gear diameter, although the ring gear diameters are the same at 8.5''
    The 30 spline count of the Dana 44 is supposed to be a little stronger than the 28 of the ten bolt, which is basically meaningless because usually the u-joint breaks first anyways, esp if you upgrade the shafts.
    Dana 44's have a greater wall thickness in the tubing. I think this isn't really an improvement compared to the 10 bolt, because the tubes aren't the problem areas.
    And its been said before, they are basically equal. The only reason to swap one for another (which is pretty easy) is for some other reason than strength...gears, 8 lugs, etc.
